76' KZ900 Body Work / Repaint....?
  • Erock
  • Erock's Avatar Topic Author
30 Jan 2016 15:37
#708623
So I'm now the new proud owner of this 76' KZ900....
I've been able to locate most of the replacement parts I need but unable to locate OEM bodywork in the green color....
Can anyone direct me to a source for new body work...or a reliable source for a quality repaint.....
Thanks, Eric
Attachment s-l1600-2.jpg not found
Too many bikes and not enough time...But that's what keeps me busy....:)
  • floivanus
  • floivanus's Avatar
Re: 76' KZ900 Body Work / Repaint....?
30 Jan 2016 15:58
#708628
Check with member paintworkz he might have the paint codes. NEW? Not likely to happen, it'd be used, and unless all the pieces were stored together probably aged differently piece by piece. If I'm not mistaken it's going to be a multi-stage candy paint job and a bit pricey, what's wrong with the current paint set?
Past; 78 kz1000, 83 kz550
Andrew
  • Erock
30 Jan 2016 17:17
#708639
floivanus wrote: Check with member paintworkz he might have the paint codes. NEW? Not likely to happen, it'd be used, and unless all the pieces were stored together probably aged differently piece by piece. If I'm not mistaken it's going to be a multi-stage candy paint job and a bit pricey, what's wrong with the current paint set?
Andrew,
The paint is faded and the tank has a dent.....So I really want a new paint job....I do have a painter that can do the job for just about $1200.....But I'd rather find a newly painted set and then I can sell the older set....
I'm sure that PaintWorkz has the paint....
  • peter1958
  • peter1958's Avatar
30 Jan 2016 17:54
#708647
I have a 76 tank that was a take off because of a small dent. THINK i paid 450.00 for it a few years ago. Where do you live?
The following user(s) said Thank You: Erock
  • Erock
02 Feb 2016 15:42
#709100
peter1958 wrote: I have a 76 tank that was a take off because of a small dent. THINK i paid 450.00 for it a few years ago. Where do you live?
Peter1958,
I'm in the Chicago suburbs...How about you?
E
  • GregZ
  • GregZ's Avatar
03 Feb 2016 03:16 - 03 Feb 2016 03:18
#709147
When you work on the bike, make sure you turn the front fender around. It's on backwards.
And whats with the front indicators ?
Last edit: 03 Feb 2016 03:18 by GregZ.
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Feb 2016 05:33
#709168
I had mine that way for a while. It looked like a eagle beak the other way. When they came out with the squared look, I turned it back around. Everything in the 80's was squared and I hated it. Only lasted a decade and now it looks cool. :unsure:
  • redhawk4
  • redhawk4's Avatar
03 Feb 2016 07:18 - 03 Feb 2016 07:18
#709188
GregZ wrote: When you work on the bike, make sure you turn the front fender around. It's on backwards.
The headlight ears have been changed for the type, which I think were on some of the later 650 models, where there's a separate hole for the indicators to mount instead of them going through the headlight bucket like they did on most of the other models and certainly the KZ900..
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Last edit: 03 Feb 2016 07:18 by redhawk4.
  • PaintWorkz
  • PaintWorkz's Avatar
03 Feb 2016 12:00
#709226
The front fender is not mounted backwards......the forks are on backwards!
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
The following user(s) said Thank You: SteveP
  • peter1958
03 Feb 2016 13:19
#709234
Lancaster co pa home of the amish mafia
