Repair Small Dent in Kerker Header Pipe
  • Vintage3
  • Vintage3's Avatar Topic Author
28 Oct 2015 07:12
#696273
Hi,
Does anyone know what the best hi-temp filler sandable product is (same effect as bondo) to deal with this ding in my header? Picture is attached. Once repaired it will be repainted. I checked paintless dent repair and they cannot fix it.
Thanks,
Re: Repair Small Dent in Kerker Header Pipe
28 Oct 2015 07:38
#696275
The dent looks pretty shallow. Your best bet may be to have someone who does brazing fill the dent. Then you can file it to the correct shape and paint it. Brazing has a high melting point, so the header shouldn't get so hot as to melt it off. The guy doing the brazing can tell you the melting point of the rod he's using. Ed
  • pete greek1
  • pete greek1's Avatar
28 Oct 2015 08:17
#696284
Sometimes muffler shops can fix it, if they can get to it with a muffler pipe expander
Pete
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
28 Oct 2015 09:30
#696293
the right size ball welded to a steel rod heat the tube beat the ball through to resize.
otherwise braze or weld.
  • barney
  • barney's Avatar
28 Oct 2015 11:09 - 28 Oct 2015 11:10
#696310
Is it worth it. The dent is almost un-detectable
Last edit: 28 Oct 2015 11:10 by barney.
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Oct 2015 11:19
#696312
I'd ignore it.
  • Kapahulu
  • Kapahulu's Avatar
28 Oct 2015 18:41
#696349
531blackbanshee wrote: the right size ball welded to a steel rod heat the tube beat the ball through to resize.
If you're going to fix it I'd try Leon's suggestion first. You can do this at home.
2strokeworld.com
  • floivanus
  • floivanus's Avatar
28 Oct 2015 18:51
#696351
The freezing water trick does work i did it last year on a 550 header
Past; 78 kz1000, 83 kz550
Andrew
  • Vintage3
29 Oct 2015 01:41 - 29 Oct 2015 01:42
#696361
Thanks for suggestions. Any ideas how hot this side of the pipe gets? What about a high heat jb weld or higher temp filler product? Recognize brasing likely the best way to go if I fix it.
Last edit: 29 Oct 2015 01:42 by Vintage3.
