Front fork trim
- Grumpy Ole Artist
- Eschew Obfuscation!
Front fork trim
11 May 2015 10:55
No eBay APP ID and/or Cert ID defined in Kunena configurationHey all!! I am a little tired of looking at naked front brake splitter....Never had a cover ON mine...This seller claims that this part is for a 78..can anyone confirm? If so, how does it mount?
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
Re: Front fork trim
11 May 2015 11:07
He's wrong; no 1978 model had a fork cover. The fork covers did not appear on KZ650 models until 1980. The 1980 KZ650-E1 (LTD) and the 1980 KZ650-F1 had them; then the 1981 KZ650-H1 (CSR) got them. I believe all the post 1980 models got them. Ed
- Grumpy Ole Artist
Re: Front fork trim
11 May 2015 11:26
Thanx Ed, I suspected that if ANYONE here knew definitively, it would be you, LOL! (soooo, if a guy WERE to say, deviate from stock just a little bit, what do the mounting bolts thread into?)
1978 KZ650 B2
Re: Front fork trim
11 May 2015 11:43 - 11 May 2015 11:44
I'm not sure, but apparently the 1980 KZ650-F1 and E1 use a bracket that the cover attaches to. The bracket may attach to the splitter? (see 1st image below).
The 1981 KZ650-H1 uses a little different bracket setup (see 2nd image). Ed
Attachment 00003a-28.jpg not found
Attachment 00003c-7.jpg not found
Last edit: 11 May 2015 11:44 by 650ed.
The following user(s) said Thank You: Grumpy Ole Artist
- floivanus
Re: Front fork trim
11 May 2015 11:44
Theres an adapter plate that bolts to the splitter and the cover bolts to that, this one's from a 1000 ltd
Attachment image-9.jpg not found
Past; 78 kz1000, 83 kz550
Andrew
Andrew
The following user(s) said Thank You: 650ed, Grumpy Ole Artist
- davido
Re: Front fork trim
11 May 2015 13:08
Yup,my CSR has the same.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- KowalskiCW
Re: Front fork trim
12 May 2015 10:07
Hey Grumpy I have an 80 LTD and that diagram is exactly how mine is. I actually just modified my stock one from the one you found on fleabay to a chrome one I bought at a swap meet. I can ship you mine for shipping cost if you want. I unfortunately modified the stock bracket so you'd still have to figure that part out. Let me know
- davido
Re: Front fork trim
12 May 2015 11:08
Heres what I have on my CSR1000,which shows you how it all goes together.Unfortunately the bracket is not available
though the kwak sign is.
www.cmsnl.com/kawasaki-1982-kz1000-m2-cs...t/66911.html#results
The whole thing bolts on to the lower yoke(triple tree) using the same holes as the splitter (longer bolts)
If thats any good to you.
good luck
good luck
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Re: Front fork trim
12 May 2015 13:52
I bought one for Bossie. I too was tired of looking at the naked area under my head light. I made a bracket out of sheet aluminum and attached it to the bolts holding my splitter.
- Grumpy Ole Artist
Re: Front fork trim
13 May 2015 07:16
Hey Kowalski, that would be cool! Where are you located? US ?
any idea of shipping costs to 45331?
1978 KZ650 B2
- KowalskiCW
