lower cowling
- gengomerpyle
lower cowling
01 Mar 2015 14:37
i bought a lower cowling from a 84 honda 750 interrupter to put on my 750R1. what would be the best way to mount it to the bike?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- Grumpy Ole Artist
- Eschew Obfuscation!
Re: lower cowling
02 Mar 2015 06:38
I have read that heavy duty "zip strips" are a common choice...You will probably have to a bit of trimming to clear exhaust
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
The following user(s) said Thank You: gengomerpyle
- rstnick
Re: lower cowling
04 Mar 2015 17:28 - 04 Mar 2015 17:50
Making brackets is the usual route.
I zip tied mine on at first, as there were 4 holes already in the corners, and tying it on was quick and easy.
The frame is right there too, so no need to work out gaps and such.
It's worked fine for a number of years now.
I do remove it at least once a year, when using stands for storage etc.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 04 Mar 2015 17:50 by rstnick.
- Grumpy Ole Artist
Re: lower cowling
05 Mar 2015 05:39
Man I have been seeing this bike around here for quite a while, & I just noticed the clear points cover! Cool!
1978 KZ650 B2
Re: lower cowling
05 Mar 2015 07:13
I like to pic with the cop car in the back ground. I sent to my neighbor, "Hey there's Jeff". Reminds me of him. The clear cover is cool too. How about fence clamps or EMT clamps?
- HBKwaka
Re: lower cowling
05 Mar 2015 07:46gengomerpyle wrote: i bought a lower cowling from a 84 honda 750 interrupter to put on my 750R1. what would be the best way to mount it to the bike?
You could use stainless P-clamps. Find the diameter of the frame, buy the rubber isolated size and you can then bolt it on without welding. Looks clean as well.
Nick-The shark mouth on your fairing is badass...
- gengomerpyle
Re: lower cowling
05 Mar 2015 14:48
ill look into the p-clamps, thanks
1982 GPZ750R1 ELR
1971 Honda CB750K
1971 Honda CB750K
Re: lower cowling
05 Mar 2015 17:53
Airtech Streamlining Has the hardware you need , and a lot of other cool pieces for Bikes including the big Kaws
The following user(s) said Thank You: HBKwaka
- HBKwaka
