Cleaning aluminum tips needed...
  • zukdave
  • zukdave's Avatar
Re: Cleaning aluminum tips needed...
06 Aug 2014 16:13
#642957
Baking soda in a small hand held sand blaster for the fin's.
As for polished fin's not a good idea the ruff finish add's surface area
to help with cooling.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • HBKwaka
  • HBKwaka's Avatar
06 Aug 2014 16:18
#642958
Coca cola for about 30 min. Try a small spot first. The alloy we cleaned was 6061 plate. Your engine is sure to be a different alloy so do a small spot test. Try different soak times until you get it where you want it. Engine aluminum may be different effect than 6061.
  • Old Rider
  • Old Rider's Avatar
06 Aug 2014 21:51
#642988
Some Semi-truck washes have the chemical you need And would probably spray some on for ya, I like the brass brush idea if nothing else. I used a old 30cal barrel brush from my gun cleaning kit. Believe it or not crest toothpaste works wonders its like a mild polishing compound but then you have to get it out of the cracks as well. Good luck whatever you do. John.
Old Dogs never Die.
  • kaw-a-holic
  • kaw-a-holic's Avatar
06 Aug 2014 23:00
#642992
Or you could have the items "chrome" powder coated. Not ad bright as polished, BUT easy to maintain.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • fastestz1
  • fastestz1's Avatar
12 Aug 2014 16:38
#643699
kaw-a-holic wrote: Or you could have the items "chrome" powder coated. Not ad bright as polished, BUT easy to maintain.[/quote
Are you sure thesewer powder coated??
Any idea where ?
  • kaw-a-holic
12 Aug 2014 17:24
#643701
It's a 2 step process. I'm having it done on mine they do the "chrome" then clear. Here is their gallery: m.flickr.com/#/photos/section_8/page12
Jon
1977 KZ1000a1
Mesa, AZ
  • kaw-a-holic
12 Aug 2014 17:25
#643702
Jon
1977 KZ1000a1
Mesa, AZ
  • kaw-a-holic
12 Aug 2014 17:28
#643703
Jon
1977 KZ1000a1
Mesa, AZ
