Adhesion Promoter
  • kzz1king
  • kzz1king's Avatar Topic Author
Adhesion Promoter
29 Jan 2014 19:05
#620555
Should I use an adhesion promoter as the first coat/primer on fiberglass? Planning on using all duplicolor rattle can products. If needed can regular primer be sprayed over the promoter?
Wayne
Home built KZ1000 turbo setup
  • Hollywoodmx
  • Hollywoodmx's Avatar
Re: Adhesion Promoter
29 Jan 2014 23:57
#620574
kzz1king wrote: Should I use an adhesion promoter as the first coat/primer on fiberglass? Planning on using all duplicolor rattle can products. If needed can regular primer be sprayed over the promoter?
Wayne
Adhesion is more for metal. If you have sanded to a 400 grit then sandable primer is fine for fiberglass.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • ZERO
  • ZERO's Avatar
30 Jan 2014 02:27
#620576
If you'll be spraying down LAQUER based primer. (most rattle can primers that are sandable are laquer based.) Use light coats. The thinning agent might attack the glass or any old paint.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
  • DoctoRot
  • DoctoRot's Avatar
30 Jan 2014 02:56 - 30 Jan 2014 02:58
#620578
depending on what type of resin was used in the composite, and if it was allowed to cure open to the air, it may be necessary to remove the outer layer as it does not fully cure unless treated in some instances. adhesion promoter helps adhesion, but is not necessary. do you know what type of resin was used? a helpful indicator is the type of fiber that was used in the composite.
Last edit: 30 Jan 2014 02:58 by DoctoRot.
  • kzz1king
30 Jan 2014 04:58
#620583
I will lok at the can. It is a Bondo product found in O Riely's and Walmarts.. It has been sanded.
Wayne
DoctoRot wrote: depending on what type of resin was used in the composite, and if it was allowed to cure open to the air, it may be necessary to remove the outer layer as it does not fully cure unless treated in some instances. adhesion promoter helps adhesion, but is not necessary. do you know what type of resin was used? a helpful indicator is the type of fiber that was used in the composite.
  • turboking
  • turboking's Avatar
30 Jan 2014 05:42 - 30 Jan 2014 05:44
#620588
kzz1king wrote: I will lok at the can. It is a Bondo product found in O Riely's and Walmarts.. It has been sanded.
Wayne
adhesion promoter is used on STEEL :huh: .......IMO, a good sealer/primer should be fine for your paint job...apply lightly for the first 2 or 3 coats and let flash between coats..... :ohmy: light coats will keep the resin used in making your body work from being attacked/softened by the thinner/reducer used in the rattle can. :blink:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Last edit: 30 Jan 2014 05:44 by turboking.
  • z1kzonly
  • z1kzonly's Avatar
30 Jan 2014 09:29
#620607
Yes, adhesion promoter is used on plastics like new car bumpers and side panels.
First of all what are you fixing? Are you painting your KZ parts? Other Motorcycle parts?
Good old laquer is what I used to use. Until the tree hugger police are trying to eliminate it.
Hope you don't live in California, suprised they are not trying to ban aerosal cans :laugh:
But nowadays, 2 part epoxy primer and urathane primers are the way to go. But this is spray gun material.
Go get your self some Krylon primer and load it up wet so you can wet sand it. whatever your painting.
  • DoctoRot
  • DoctoRot's Avatar
30 Jan 2014 13:45 - 30 Jan 2014 13:53
#620648
z1kzonly wrote: Yes, adhesion promoter is used on plastics like new car bumpers and side panels.
i have only heard of it used on plastics as well. there are much better primers available for metal than adhesion promoter. like self etching and epoxy primers.
If you sanded it you are good to go! I have parted molds before and had poor adhesion with paint because the outer layer was not treated chemically or mechanically. This is a characteristic of orthophthalic resins and other polyester resins.
Last edit: 30 Jan 2014 13:53 by DoctoRot.
  • kzz1king
30 Jan 2014 17:34
#620667
I plan on using Dupli color products, So is there a type of primer I can use for both the tank and the fiberglass seat? Self etching the way to go?
Wayne
  • z1kzonly
  • z1kzonly's Avatar
30 Jan 2014 19:10
#620676
Self etching primer is like an acid wash to metal.
It is only for bare metal! Then you use your sandable primer on top of it.
Find a person with a compressor and a spray gun give him 25 bucks just to prime it for you.
Then use your rattle cans. Or.
Just use Krylon gray primer on it all.
