KZ750 Tank... Modify or Replace?
- NSpinicelli
22 Nov 2013 10:28 - 22 Nov 2013 10:31
I'm working on my first cafe racer, a 1976 KZ750 Twin. One of the most beautiful pieces on a cafe racer for me is the tank, which I am not a fan of when it comes to the OEM tank for this bike (picture #1). Could a metal worker modify/reshape the tank, or would it be better to replace it entirely in order to produce a tank similar to picture #2? Thoughts? Any referrals?
Attachment 857245_10153322361510128_1791273475_o.jpg not found
Attachment images.jpg not found
Last edit: 22 Nov 2013 10:31 by NSpinicelli. Reason: Modifying pictures
- StreetfighterKz
Re: KZ750 Tank... Modify or Replace?
22 Nov 2013 11:07 - 22 Nov 2013 11:08
A good automotive bodyworker should be able to modify it as needed. One of the older tricks is to trace a "knee dent" on a piece of cardboard and cut it out. Position it exactly in the same spot on each side and cut the tank around the template. Take the left piece and right pieces and weld them on the opposite sides. (It's more in depth than that but I left out some finer details for simplicity). Because the tank is convex and you flip the pieces to the opposite side they become concave and form "knee dents".
Here is sorta what I'm talking about.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 22 Nov 2013 11:08 by StreetfighterKz.
- NSpinicelli
22 Nov 2013 11:51
That's good to know, and also a great idea! I've never thought of doing that... Thanks for the response StreetFighterKZ!
- DoctoRot
everybody loves the Benelli tanks. i doubt dishing the tank will give you the look you want. if you like the Benelli tank find one one ebay. it will take some fabrication to make it fit. you could sell your tank to offset the cost.
23 Nov 2013 05:59
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationThere are some Benelli tanks on eebbaayy but most are pricy.
DimeCityCycles has tanks but they're expensive.
