Gas tank liner!
  • jmoney05
  • jmoney05's Avatar Topic Author
Gas tank liner!
10 Oct 2013 03:55
#609479
Anybody use a product called red Kote? It is a gas tank liner of some sort. Giving my tank a new paint job and body work, figured I coat the inside of the tank while I was doing everything else.
1978 Kz650D
  • coolio2013
  • coolio2013's Avatar
Re: Gas tank liner!
07 Nov 2013 19:36
#612387
I've never used a tank liner myself...I've cleaned them using vinegar...pain in the ass ordeal...but does work...
I've seen a new product to line gas tanks (if they are rusted) that the new gasoline doesn't affect it.
It's an ad in the Café Racer mag...searching...ok my mistake...readers of that mag don't actually fix their own bikes...
Found it www.flowliner.co.uk
Hope that helps,
These are my bikes:
1977 GS750B
1983 GS750E
1984 KZ750
1991 ZX7
1986 1000R
1982 KZ1000J
1982 KZ1000K
No room for anymore bikes...
Re: Gas tank liner!
07 Nov 2013 19:42
#612392
Unless the inside of your tank has problems I would not coat it with anything. If tanks are kept reasonably filled with fuel they won't rust or leak. However, tank liners will fail over time and cause issues in the tank, and unless you have a quality in-line fuel filter can cause problems in the carbs. Ed
The following user(s) said Thank You: jmoney05
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Gas tank liner!
07 Nov 2013 19:48 - 07 Nov 2013 19:55
#612393
I would only coat if it was very rusted and pitted.
These coatings can be tricky and are prone to fail.
I would try to clean first....several people on here know how to do it. ......as this topic has come up before.
www.kzrider.com/forum/3-carburetor/26616...-inside-of-fuel-tank
www.kawasakimotorcycle.org/forum/mechani...inside-gas-tank.html
www.kawasakimotorcycle.org/forum/kawasak...ing-my-gas-tank.html
wn.com/how_to_clean_a_motorcycle_gas_tank_that_is_rusted_inside
Last edit: 07 Nov 2013 19:55 by 4TheKZ1000.
  • Drooz
  • Drooz's Avatar
Re: Gas tank liner!
03 Jan 2014 17:33
#617239
I agree with all the above statements. Resist the urge to line your tank unless there's no other alternative. :(
However, if you must, consider Caswell's epoxy liner. It seals leaks and has been inside my KZ1000 tank for 7 years with no issues. :cheer: It ain't cheap, but...
You get what you pay for, IMO. B)
Canada:
www.caswellcanada.ca/shop/
USA:
www.caswellplating.com/restoration-aids/...gas-tank-sealer.html
Good stuff! ;)
Good for fibreglass tanks as well. :kiss:
'77 kz1000 (zx10r) Modified/Street
'81 GPz550 "TrackBike"
'05 zx10r Retro/Mod Sportbike 4 SALE!!
'02 zrx1200r Lightly Modified Street SOLD!!
'74 h2b 750 (FZ600) "Mongrel" 2 Stroke SOLD!!
"Invictus Maneo" - I remain unvanquished.
Kawasaki - Let The Good Times Roll!
Mississauga, Ontario. CANADA
  • kaw-a-holic
  • kaw-a-holic's Avatar
Re: Gas tank liner!
03 Jan 2014 18:39
#617241
POR 15 is what I use, its awesome. I personally have never had an issue with it and have not talked to anyone who has used it and not liked it.
www.ridermagazine.com/gear/por-15-fuel-t...pair-kit-review.htm/
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • kaw-a-holic
Re: Gas tank liner!
03 Jan 2014 18:40
#617242
stay away from Cream, its garbage.
Jon
1977 KZ1000a1
Mesa, AZ
  • Drooz
  • Drooz's Avatar
Re: Gas tank liner!
03 Jan 2014 19:13
#617243
There are probably several ways to go here. IMO, it's all about the surface prep. It doesn't mater what you're putting a coat of paint (for example) on. The better the prep, the better the finished product.
Whatever you decide on, read the instructions carefully and follow them to the letter. :)
  • dkoz
  • dkoz's Avatar
Re: Gas tank liner!
03 Jan 2014 19:29
#617246
I bought my ltd not running. and was told the carbs wear junk would not run..
For the quick fix I bought a new set of carbs and the bike ran for a couple days and then just stopped .found what looked like brown sugar in the bowl's and new right then that even though the tank liner looked great it had to be failing somewear..
The previous owner used cream it took 6 weeks of acetone soaks along with tumbling fish gravel once a week just to get that shit out of the tank.
Not to mention the few weeks of trouble shooting and spending before finding out what was wrong...
I've been told by MANY people on this site that unless theirs some sort of leak in your tank resist the tank liners.
I used a 25 dollar tank kit from Yamaha its a 2 bottle process and just keep fuel in it and it won't rust..and if you do line your tank the PREP is most important ..
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
  • dkoz
  • dkoz's Avatar
Re: Gas tank liner!
03 Jan 2014 19:32
#617247
The 2 bottle Yamaha kit is just an acid wash to remove the rust.and then a neutralizer
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Gas tank liner!
04 Jan 2014 06:32
#617280
I have Kreme in mine now going on 7 years, no issues here....
As with any product, don't give a crap what it is, if prep work and detail isn't followed to specs, going to turn out like shit no matter what.... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • turboking
  • turboking's Avatar
Re: Gas tank liner!
04 Jan 2014 07:14 - 04 Jan 2014 07:15
#617281
:( I've seen so many bad Kreme jobs over the years..... always flaking and peeling :angry: .....It may have been like OMR said ,BAD PREP JOB :unsure: :unsure: ;) I use a 2 part epoxy that's silver after mixing and it is rock hard after curing a few hours..... sealed all pin holes on a badly rusted tank..... of course I did a acid etch rust removal before lining/sealing .....ethanol/race fuel proof. ;)
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Last edit: 04 Jan 2014 07:15 by turboking.
