Gas tank liner!
- Dr. Gamma
Re: Gas tank liner!
04 Jan 2014 13:54 - 04 Jan 2014 13:58Old Man Rock wrote: I have Kreme in mine now going on 7 years, no issues here....
As with any product, don't give a crap what it is, if prep work and detail isn't followed to specs, going to turn out like shit no matter what....
Like Mr. Rock said, its all in the prep, and following the directions. I coated my MK II tank back in '80 with Kreem. And till this day it has no issues what so ever!!! Plus I stored the bike the last 10 years or so with some Unocal 76 leaded race gas that I left in the tank. I just found that out last week when I moved the bike out of storage. I turned one of the petcocks on to see if the lever was still free and this pink stuff ran out all over the place.
I used muriatic acid to etch the inside of my tank back then. Make sure there is not ONE DROP OF WATER left in that tank before you pour the Kreem in. The Kreem WILL NOT stick to any wet spots inside of tank. Another thing I also do is that I coat the tank as soon as it is dry. Not the next day, but right after I dry the inside of tank.
I never used Kreem that was shipped in real cold winter weather. Shake the living hell out of it before you pour it in too. After I made sure I had a good coating all the whole inside of tank, I would drain the excess out through the threaded petcock mounting bosses. I would then pour it back in, and put like a second coat inside the tank before the first coat had completely dried. I tried to get all of the remaining Kreem out of tank by angling the tank downward toward the petcock opening. You will not believe how much extra Kreem comes out of the tank when you do that. I would then leave the tank out in the sun for two or three days before I would put fuel into it.
The Kreem liner inside my tank has turned from white to a pink color from the Unocal gas I used to run in my bike. I also used VP C12 and C14 over the years too. I have done something like 15 to 20 tanks over the past 25 years or so, and not one of them did the Kreem coating not dry, or flake off over the years the bikes were used.
1986 RG500G 2 stroke terror.
Last edit: 04 Jan 2014 13:58 by Dr. Gamma. Reason: badd grammer
- turboking
Re: Gas tank liner!
04 Jan 2014 16:10
i've seen Kreme fill the fuel bowls on carbs with the pink slime.... :blink: I didn't do theKreme install on any of the tanks that I've seen this happen to.......I just cleaned up the mess.....the kreme in all of these tanks had turned pink ......... :sick: Poor installation or Ethanol I guess , it was dissolving the liner for some reason.....that's why I go with the two part epoxy....... No kreme for me :pinch:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- Drooz
Re: Gas tank liner!
04 Jan 2014 19:35
Ya, like I said, prep, prep, prep!!
With the sketchy fuels out there these days, if you're gonna line a tank, I'd still recommend an epoxy liner such as Caswell's.
'77 kz1000 (zx10r) Modified/Street
'81 GPz550 "TrackBike"
'05 zx10r Retro/Mod Sportbike 4 SALE!!
'02 zrx1200r Lightly Modified Street SOLD!!
'74 h2b 750 (FZ600) "Mongrel" 2 Stroke SOLD!!
"Invictus Maneo" - I remain unvanquished.
Kawasaki - Let The Good Times Roll!
Mississauga, Ontario. CANADA
- Topper
Re: Gas tank liner!
04 Jan 2014 19:48
I tried red kote on a tank with a microscopic pinhole leak. It didn't work despite following the directions to the letter.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- Old Man Rock
Re: Gas tank liner!
05 Jan 2014 06:19 - 05 Jan 2014 06:27This slime bypassed the In-line fuel filter, really it didn't stop this...? :SKreme fill the fuel bowls on carbs with the pink slime
In case others are concerned, Ethanol here in AZ during winter moths, tank liner still off white color as was from day one....
If truly worried about the liner product(s):
The tank cleaner alone would more than likely be enough on 98% of most rusted tanks....
Translation, most kits are 3 parts for tank lining. Part one is to clean out the rust only (no sealing), similar to acid wash. The tank is completely filled and left over night to break down the rust....
If the wash isn't dripping out the seams, then truly no reason to line the tank if you choose, just get rid of the rust and call it good as new...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 05 Jan 2014 06:27 by Old Man Rock.
- zed1015
Re: Gas tank liner!
05 Jan 2014 06:32
I would avoid any type of tank liner/sealer unless it is unavoidable and you need to stop a leak without ruining the paint work.
If you are repainting anyway then get the job done correctly and have the tank welded or brazed.
If the tank doesn't leak then applying sealer for the sake of it is just a waste of time and money.
- turboking
Re: Gas tank liner!
05 Jan 2014 07:49 - 05 Jan 2014 07:52
I don't know about ethanol levels elsewhere ,but since we here in the (Ohio,KY. IND. area) U.S. are subject to ETHANOLfrom corn ..... :sick:
I get this crap full (10% min.) time :sick: . thanks to our EPA... any early 80's tank that I am going to repaint and spend money on to paint , get's sealed....... :dry: Nothing nicer than investing in a new paint job to have it ruined by leaks ..... For me, 2 part epoxy tank sealers have proven to be impervious to :evil: ETHANOL :evil: AND race fuels :S they do not break down or fail /come off if prep is done properly :S
Ethanol site quote : Is ethanol corrosive ?
Yes , ethanol is corrosive, but not very much. Gasoline is corrosive too. Ethanol is biodegradable in water. So it has a tendency to contain and attract water. It is not the corrosive properties of ethanol that can cause damage to your vehicle; it is the water which can rust a vehicle’s fuel system from the inside out. Today’s vehicles (since mid 1980s) have fuel systems which are made to withstand corrosive motor fuels and rust from water. quote
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
Last edit: 05 Jan 2014 07:52 by turboking.
- floivanus
Re: Gas tank liner!
05 Jan 2014 10:13
Turbo king what two part epoxy do you use?
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- dkoz
Re: Gas tank liner!
05 Jan 2014 11:55.floivanus wrote: Turbo king what two part epoxy do you use?
I have a set of original paint Harley tanks someone coated .. its gray in color. Don't know what it is ..hard as a rock with crappy indiana fuel in it for 10 years now no issues.
Wondering if this is what turbo king uses..?
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
- Drooz
Re: Gas tank liner!
05 Jan 2014 13:22zed1015 wrote: I would avoid any type of tank liner/sealer unless it is unavoidable and you need to stop a leak without ruining the paint work.
Another reason to use an epoxy liner is on a fibreglass tank. Modern fuels aren't compatible here either.
- turboking
Re: Gas tank liner!
05 Jan 2014 14:26floivanus wrote: Turbo king what two part epoxy do you use?
last time I bought a 3 quart kit (2 qt's of epoxy and 2 pints of hardener) . you have to get your own cleaner......1 kit (1 qt /1 pint) will do a big KZ tank with a little left over.... it's silver after mixing , flows like warm pancake syrup...... and it gets real hard after curing.... I will have to check the cans label (read: dig em out) :dry: when it gets a little warmer.....Brrrrrrr. :S
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
Re: Gas tank liner!
05 Jan 2014 21:12dkoz wrote: . . . I have a set of original paint Harley tanks someone coated .. its gray in color. Don't know what it is ..hard as a rock with crappy indiana fuel in it for 10 years now no issues. . . .
Am pretty sure that some Harleys came from the factory with lined fuel tanks.
But am uncertain as to what years or whether Harley still does this.
