paint compatibility
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar Topic Author
  • Eschew Obfuscation!
paint compatibility
19 Sep 2013 16:14
#607088
Repainting on the cheap, FINALLY tracked down rattle can Candy Blue
My favorite lacquer(duplicolor) was discontinued, the new candy is a urethane.
My base coats are Silver rattle can lacquer. Any compatibility issues
of which I should be aware? ( Really would rather not have to strip, & reshoot now, or , even worse, have it blister, etc later...Thoughts? Any painters out there?
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
  • racer54
  • racer54's Avatar
Re: paint compatibility
19 Sep 2013 16:46
#607096
Been many years since I've painted but you don't want to paint lacquer over enamel. You can paint enamel over lacquer though. Best to spray a sealer between coats to seal old paint to be sure though. Hopefully, the pros on here will chime in to help you though...
  • DoctoRot
  • DoctoRot's Avatar
20 Sep 2013 00:02
#607124
if possible do a test on something else.
  • PaintWorkz
  • PaintWorkz's Avatar
21 Sep 2013 03:54
#607229
Not recommended but it will work. Probably can't sand through to repair it at a later date. Adhesion might be an issue when taping/masking. Let the lacquer base silver dry real good before spraying the urethane top coat.
Yes, best to test spray all the products you plan to use on the project, like final clear, on a small part.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
  • Grumpy Ole Artist
07 Oct 2013 12:35
#609100
Thought I would stick a picture in here...she's coming along nicely...the different types of paint seem to be "stacking up" just fine....Keeping my fingers crossed!!! (Blue is faster, LOL!)
1978 KZ650 B2
