Fender and side cover paint removal
20 Aug 2013 14:08 #602319 by geerbangr
Fender and side cover paint removal was created by geerbangr
What would be the safest way to remove the paint fron the side covers and the rear fender of my old 78 kz ? The paint is full of cracks and needs to be removed.
1978 KZ 1000
I go by Jason
20 Aug 2013 16:05 #602332 by Kidkawie
Replied by Kidkawie on topic Fender and side cover paint removal
Just sand it down.
DO NOT use paint stripper, it will soften/damage the plastic. Been there, done that! Took forever to repair.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
20 Aug 2013 19:26 #602357 by DesertKZ
Replied by DesertKZ on topic Fender and side cover paint removal
Start with 120 and be careful when you get down to plastic. Move up to 220, 320, 400 prime then wet sand the 400. Should be good.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
21 Aug 2013 00:11 #602401 by Patton
Replied by Patton on topic Fender and side cover paint removal
Perhaps brake fluid to remove paint from the side covers --
www.kzrider.com/forum/6-paint-a-bodywork...emoving-paint#504596
Good Fortune! :)
21 Aug 2013 12:11 #602458 by geerbangr
Replied by geerbangr on topic Fender and side cover paint removal
Thanks for the ideas guys. Has anyone soda blasted the plastic parts ? Wonder if the soda blasting process would damage the plastic :whistle:
1978 KZ 1000
I go by Jason
02 Sep 2013 08:53 #604422 by OneShoe50
Replied by OneShoe50 on topic Fender and side cover paint removal
I had ggod luck using walnut shells and a media blaster. Took three layers of paint off and didn't hurt the plastic.
77 KZ1000A1 - Under going a psuedo ELR overhaul
79 KE175 (gone)
81 KZ550A2 (gone)
81 KZ750E (gone)
Sure it looks OK now, but wait until I really make it pretty, with some chrome and paint and some new tires and grips and the wiring. Don't forget the gearing, and the LED's and, and, and....
02 Sep 2013 17:11 #604508 by geerbangr
I may give walnut shells a whirl.What kind of air pressure did you find that worked the best using walnut shells,OneShoe?
1978 KZ 1000
I go by Jason
  • guitargeek
  • Elitist, arrogant, intolerant, self absorbed.
02 Sep 2013 20:41 #604537 by guitargeek
Replied by guitargeek on topic Fender and side cover paint removal
I'm about to try soda blasting on one, I'll take pics.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
05 Sep 2013 00:31 #604929 by geerbangr
Alright that would be great guitar :woohoo:
1978 KZ 1000
I go by Jason
  • guitargeek
05 Sep 2013 21:34 - 07 Sep 2013 07:34 #605104 by guitargeek
All day ordeal, and the soda wouldn't touch the stickers (stripes and Police 1000 sticker).
I broke out the heat gun and pulled the decals off, then hit it with 220 grit on the vibro sander.
Where the soda blasting does come in handy is getting into little nooks & crannies, and it does a nice surface prep for paint.
[IMG
Last edit: 07 Sep 2013 07:34 by guitargeek.
06 Sep 2013 14:57 #605224 by geerbangr
Well scratch the soda blasting the panels. I actually despise body work. I have some half used glass bead that may fit the bill for removing the paint off the panels. When I get home in a couple of weeks I'll try it and report back.
1978 KZ 1000
I go by Jason
  • DoctoRot
18 Sep 2013 13:36 #606934 by DoctoRot
Replied by DoctoRot on topic Fender and side cover paint removal
try using brake fluid. worked good for me before. or you might wan to give this a try but ive never used it before. www.autobodytoolmart.com/klean-strip-pai...yw1bkCFWuCQgod6RMA2A
