Brake calipers - special paint needed?
  • savedrider
  • savedrider's Avatar Topic Author
  • 1975 Z1-B 900
21 Jul 2013 21:09
#597614
Getting ready to paint my front brake calipers. Do I need to worry about using a special high temp paint? Looking to do black semi-gloss. Thanks.
Get right or get left! <*{{{><
  • DoctoRot
  • DoctoRot's Avatar
Re: Brake calipers - special paint needed?
22 Jul 2013 01:32
#597656
You will want a high temp paint. There is caliper specific paint made as well. If you want something that will withstand brake fluid check out KG coatings, Gun Kote. Some members on here have painted their whole engine as well with that stuff.
www.kgcoatings.com/protective-coatings/2400-series-gun-kote/
  • baldy110
  • baldy110's Avatar
22 Jul 2013 13:34
#597706
I have been using POR-15 gloss black top coat on all my calipers for awhile now and been really happy with it. Been also using it on all my engine cases, very tough stuff and looks great.
[IMG
[IMG
[IMG
[IMG
  • savedrider
  • 1975 Z1-B 900
22 Jul 2013 15:48
#597731
Thanks for all the feedback. I see Autozone sells a caliper specific paint. I'm going to try it out.
Caliper Paint
  • martin_csr
  • martin_csr's Avatar
22 Jul 2013 16:01
#597734
FWIW. I painted my Fr Br caliper w DupliColor brake caliper spray paint & baked the parts in the oven to cure. Although the paint has held up well, the brake fluid has ruined it around the bleeder nipple.
  • savedrider
  • 1975 Z1-B 900
23 Jul 2013 13:32
#597894
I bought the VHT caliper paint last night. Part of the instructions call to bake in the oven at 200 degrees for 1 hour for proper curing. My only concern is I did not remove the seals or dust boots as they are in good condition and I did not want to disturb them. Am I still ok to bake at this temp or will it melt/ruin the seals? Thanks.
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
23 Jul 2013 14:29
#597905
it will ruin the seals, remove them or better yet replace them after there cured after you removed them pre bake.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
The following user(s) said Thank You: savedrider
  • savedrider
  • 1975 Z1-B 900
23 Jul 2013 14:37
#597908
Thanks for the heads up!
  • bluej58
  • bluej58's Avatar
23 Jul 2013 20:32 - 24 Jul 2013 00:21
#597964
I would take it apart spray it down with brake cleaner and scrub it real good with soap and water followed by rubbing alcohol then a lite sanding and more rubbing alcohol then paint and bake .
worked for me ;)
JD
78 KZ1000 A2A
Last edit: 24 Jul 2013 00:21 by bluej58.
  • savedrider
  • 1975 Z1-B 900
06 Aug 2013 14:55
#600103
Fresh baked calipers anyone? :P
[IMG
  • Forrest
  • Forrest's Avatar
  • The Mad Duck
10 Aug 2013 14:49
#600698
Nice Looking! Great job! And, to think all I did was follow JD's procedure: brake cleaner, sand, alcohol, fine grit sand, alcohol. Except, I simply used flat black Krylon on the repaint! :silly: It is holding up just fine. But that powder coating is the schiz nitz! B)
  • kaw-a-holic
  • kaw-a-holic's Avatar
16 Aug 2013 02:56
#601649
Dupli-Color ceramic caliper paint, $20
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
