- Thank you received: 99
Painting a KZ900 - Advice Needed
- NakedFun
So I have been getting quotes for painting my project bike's tank, tail, side covers, and front fender. Going to keep it somewhat original looking, but change the A4 Diamond Green to 2005 Jaguar Racing Green and painting the stripes instead of using the decals. I am also chaging the lime green colored stripe to silver. So my quotes are ranging from $1200 - $1900 to do this. Seems a bit high, but who am I to judge..... So in my previous life, I used to work at Muscle Car Restorations where we did very high end resotorations and custom cars. I did everything thing there except lay the base, clear and wet sand the car. So I am fairly used to some level of quality body work.
This got me thinking, I always farm out my painting projects on my cars and bikes, and perhaps that should change. I have a place that I can build a makeshift cross draft paintbooth. I would have to pick up a couple of guns and tips/needles. I have all the other body working tools needed. Of course, I would need to pickup a full course of paint, primers, fillers, paper, clear, polish, etc... So my questions are:
1. Any recommendations on guns/kits? Looking at a kit from Devilbiss which is their 2 gun Finishline kit which is available through Eastwood and TCPTools.
2. My stock paint is in good, but faded/old condition. Do you think it would be OK to just sand and level that and paint over it or do I really need to take it all the way down to bare metal? Does anyone know what the stock paint was? I looks like laquer based paint to me....
3. So with three colors, anyone have a WAG or idea of cost for a good quality urethane or enamel (base & clear)? Is this $500 or $200 or even $1000 dollars worth of material? Also, do you think a quart of the base color is enough to do the pieces I had listed above for multiple coat coverage?
Any advice would be appreciated.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
- DesertKZ
- Thank you received: 20
Attachment Stang3.jpg not found
Attachment Stang1.jpg not found
NakedFun wrote: All,
Cory
I've painted a few cars in "garage" booths, most recently this '69 Mustang from start to finish. To prove I could do it on a budget, I used a Harbor Freight gun and Summit Racing Paint. It was a basecoat clearcoat job and turned out awesome. 5 years or so ago this was done and up until I sold it paint held up beautifully, the new owner shows this car on a weekly basis. I think 2 quarts tops and a single stage enamel would work fine for you. Check out Summit.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
- NakedFun
Cory
1976 Kawasaki KZ900
- moneypit
- Thank you received: 35
Bob
2-76 kz900
St Paul MN
- NakedFun
Yep they are near my work with their Columbia Heights location. I deal with them a fair bit and I know they have quite the body supply stock. I had read posts on the HF guns, and posts after 2010 seem to imply that the guns have changed since 2010 and they are worse. Don't know if it is true or not....
Cory
1976 Kawasaki KZ900
- mopguy
- Thank you received: 168
- bluezbike
- Thank you received: 104
79 KZ 1000 LTD
- NakedFun
Cory
1976 Kawasaki KZ900
- ramtough_63
i did some airbrush work and have helped him on a couple jobs. we had a discussion about what paint gun I would need for a few paint jobs a year (1 a month) he advised me on not refinancing the farm for a paint gun. the only reason to buy the higher end guns as with any tool is for production work most people dont buy snap on tools to do occasional work. Paint Guns are no different
Case and point he bought me a high end airbrush well over 300.00 ( I have always used the workhorse brush I could find deals on for 59. to 79.00 (paasche VL) The iwaata is an awesome air brush but not using it every day it takes a complete overhaul each time I use it. and isn't as good as my workhorse for some things and better at others
I have sprayed with his paint gun and it sprays beautifully it has the inverted cup so it feeds at any angle super easy to clean etc...
remember the old attage it's not the violin it's the violinist. harbor freaght 2.0 nozzle gun atomizes the paint well lays down as smooth as any gun I have used
cleaning it takes a little more effort because I dont use it every day
I clear with the 1.3 nozzle HB gun for motorcycles a little hard to get the volume of paint but
it burns in and lays cleaner than pouring the clear on with the 2.0
assuming your compressor will handle it (mine is my week link)
I had 600.00 to buy a gun with and ended up with 3 harbor freight guns and plenty of product a steak dinner. at his advice 5 paint jobs later I neglected my clear gun did a total cleanout cleanup and its is back in business
ok now I have shared my gun experience lets talk paint
I started out with kirker paints the most expensive clear they sell is 79.00 plus catalyst right at 110.00 plus tax
first paint job was a practice paint job on a buddys bike worked well then painted my green bike
did a few more using combination of systems
bought kirker base coat house of Kolor metal flake, and accent color and my trusty ol top of the line clear.
beatuful paint job 6 months later clear has yellowed talked to one of the painter at the shop he tells me the clear they use on silver and white is a little over 200 a gallon plus catylist
I have switched to PPG base coats house of Kolor accents (and wicked) the cost of supplies has doubled but if you shop wisely TCP global and auto body depot on ebay (same company) bought a quart of PPG Grabber blue un reduced 50.00ish dollars same quart would be between 160.00 and 300.00 here locally
I have been lucky and able to get a small quanities of over mixes for pennies on the dollar
remember a pint makes a quart mixed plenty to lay a base coat on tank tail side covers and fairing.
moral of the story no matter what you spend on a gun it all comes down to how well you use it and what materials you use the cheaper paints are decent and the high end paint is well...high end as long as your laying it that way.
reminds me of my cousin who is an extremely talented guitar player used to make my fender squire
scream nobody would believe he was playing 100 guitar
keep a cheap gun clean buy plenty of diposable cups and buy quality paint and you will have better results as long as you play it well
keep an expensive gun clean buy mediocre meterial get medocre results
and we havent even discussed color sanding and buffing lol
hope this helps
I was very suprised that he didnt tell me you get what you pay for when I asked him to get me gun like his. He told me in his words "if your using it everyday I'll order you one but if its gonna sit around your wasting your money"
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- NakedFun
I am working on finding colors, and was just on TCP Global's site as they have a green that is really close to the Jaguar Racing Green I was looking for. I also need to be thinking about pin striping masking tape so I can paint the stripes into the tank.
Cory
1976 Kawasaki KZ900
- bluezbike
79 KZ 1000 LTD
- NakedFun
Cory
1976 Kawasaki KZ900
