solution for tank rust
- stunter956
09 Dec 2012 18:21
weve been cleaning tanks with vinegar and baking soda for a while now and trust me this works, pour some baking soda in the tank first then fill it with vinegar, next grab a piece of metal and a battery charger, connect the positive to the piece of metal and make sure it only makes contact with the vinegar, DO NOT LET IT TOUCH ANYTHING, connect the negative anywhere outside the tank so it could make some ground, let it sit for a day and watch the majic happen, once its done, flush the solution out, rinse with gas to clean out the left over residue and fill it up with gas again, thatll keep it from rusting again, oh and make sure to always keep it full if u can, i did that with many tanks and they are still up and running,
1976 kz900 "mean green"
- ramtough_63
Re: solution for tank rust
09 Dec 2012 18:40
I just read that at the end of another post at what amp are you using the chqarger or will a floating type tender/charger work its basicallt electrolosys they neutral lizw aluminum that way to anodise it if I remember right
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- stunter956
10 Dec 2012 16:19
u can leave it at 6 amps if ud like, usually does the trick, idk about the floating tender, never used one of those for the job.
