Anybody Tried the "Speed Blaster"?
  • Topper
  • Topper's Avatar Topic Author
17 May 2012 08:32 - 17 May 2012 08:38
#522869
I'm looking for a way to clean up and restore some of my aluminum engine parts. I've seen some DIY instructions for building a simple soda blaster, then I found this hand held sand blaster from Harbor Freight.
The idea of sand blasting without a cabinet sounds like a giant mess, but for soda blasting, I figure that'll just wash away.
Anybody ever used one of these? How's it work for soda blasting?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Last edit: 17 May 2012 08:38 by Topper.
Re: Anybody Tried the "Speed Blaster"?
17 May 2012 08:58
#522873
Topper wrote: I'm looking for a way to clean up and restore some of my aluminum engine parts. I've seen some DIY instructions for building a simple soda blaster, then I found this hand held sand blaster from Harbor Freight.
The Harbor Freight soda blaster probably works just fine.
The DIY versions are also interesting.
www.kzrider.com/forum/21-tools/318083-budget-soda-blaster
kawpen.edebris.com/forum/viewtopic.php?f=9&t=2049
www.aircooledtech.com/tools-on-the-cheap/soda_blaster/
www.garagenight.tv/diy-soda-blasting-build-your-own-rig-cheap/
Good Fortune! :)
  • Motor Head
  • Motor Head's Avatar
17 May 2012 09:30
#522879
I've used that one and 2 others from HF with good results, they have a couple of blast medias there also. I've used the Walnut Shells on a few things, they work pretty good if the part is not terribly gross. I've never tried using Soda though.
  • Kawickrice
  • Kawickrice's Avatar
17 May 2012 10:34
#522895
I have that same one I use with soda and it will get the job done. Not bad for the price
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
17 May 2012 10:48 - 17 May 2012 10:50
#522898
For $20 you can build a soda blaster and also buy 3 large boxes of baking soda.
Those speed blasters can work "ok" but you run out of media quick. Also, I don't buy specific media for blasting because it costs too much. I buy regular baking soda from the grocery store and $3/bag play sand from Lowes. I have to sift the play sand though but it works great in my gravity feed sand blaster. Sand and soda both wash away.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 17 May 2012 10:50 by Kidkawie.
  • Medina
  • Medina's Avatar
17 May 2012 11:18
#522901
After you're done, use high pressure air to blow as much of the soda off as you can, then wash the bike big time...if you dont, you'll get soda that can dry and stick to the surface and dam hard to remove.
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
  • Topper
17 May 2012 11:29
#522903
This sounds pretty promising. Is it safe and controlable enough to soda blast the engine block, head, etc. all in place?
I figure I'll remove the painted parts and mask off most of the stuff I don't want to blast. I assume I'll want to get electrical wires, brake lines, etc. all out of the way or safely covered.
1979 KZ750 Twin
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
18 May 2012 10:04
#523079
I soda blasted my Z1 like this:
1975 Z1 900
2004 KX125
  • Topper
18 May 2012 10:15
#523080
Oooh... shiny!
Did you pull the carbs off? I'm a little worried what the soda will do to the holders and boots.
1979 KZ750 Twin
  • Kawickrice
18 May 2012 11:31
#523101
I buy a 50 pound bag of soda from Harbour Freight for $35. It will do quite a bit before you run out
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
18 May 2012 11:42 - 18 May 2012 11:43
#523105
Topper wrote: Oooh... shiny!
My soda blaster is only 1/2 or 3/8 tubing so you can pin point where you aim it. It's not like a fire extinguisher. lol
I sealed up the top of the airbox or any opening. It will remove some paint, so watch your frame. But you don't need to mask every single thing. Like Medina said, you'll have to wash the crap out of your bike when you're done, all in between the fins and crap. I found some a few weeks later in the header collector. lol
You can do complete wheels too. I did a bunch of MX wheels, but my Z1 rear hub is polished so no soda for that.
1975 Z1 900
2004 KX125
Last edit: 18 May 2012 11:43 by Kidkawie.
  • Topper
18 May 2012 17:06
#523178
Ok, I've picked out my air compressor.
When it comes to a soda blaster, I'm torn between Harbor Freight's $20 hand held blaster and the $40 portable blaster
I know they make a unit specifically for soda blasting, but it's too expensive. I know there's lots of DIY plans out there for soda blasters and they look pretty simple, but I think I (or my wife actually) might want to do a little sand blasting for other projects too.
1979 KZ750 Twin
