Removing Paint from Metal?
  • 750steve
  • 750steve's Avatar Topic Author
01 Nov 2011 11:59
#486478
Is it ok to use a heavy duty paint remover on the tank to strip it right down to bare metal?, just the outside
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • porchev914
  • porchev914's Avatar
Re: Removing Paint from Metal?
01 Nov 2011 12:04
#486479
You can use just about anything you want to strip that tank ;) but I assume you are referring to a chemical stripper?
FRANKEN Z!
  • 750steve
01 Nov 2011 12:52 - 01 Nov 2011 12:54
#486487
Yes, i am indeed, chemical stuff. Its called Nitromorus here in the UK but im dure its the same as any thick nearly gel type paint remover.
Are the tanks on these bikes steel or alloy? (I'm guessing steel)
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 01 Nov 2011 12:54 by 750steve.
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
01 Nov 2011 13:51
#486490
I used a wire cup brush attached to my angle grinder to strip the frame parts of my A1. It took no time at all! I will be using it to strip the tank, side cover and oil tank as well. Just make sure you have eye protection, gloves, thick clothing, and a hat on as well. I pulled one of those little metal pieces from the stripper out of my scalp (wasn't wearing a hat), and another member said he pulled a bunch out of his arm when he used one before.
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
  • 750steve
01 Nov 2011 14:31
#486499
clutch wrote: I used a wire cup brush attached to my angle grinder to strip the frame parts of my A1. It took no time at all! I will be using it to strip the tank, side cover and oil tank as well. Just make sure you have eye protection, gloves, thick clothing, and a hat on as well. I pulled one of those little metal pieces from the stripper out of my scalp (wasn't wearing a hat), and another member said he pulled a bunch out of his arm when he used one before.
:lol: I read that in your build thread! fook that!! :lol:
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • MFolks
  • MFolks's Avatar
01 Nov 2011 15:16
#486503
Most of the liquid strippers used to have a nasty chemical in it called Methlyl Chloride, The EPA over here has acted on reducing the amount in these strippers as it can be dangerous to inhale, damaging the lungs.
If you're using a stripper with this in it, do it in a well ventilated area,chemical resistant gloves,eye protection,some disposable paint brushes, and something in which to scrape with that won't scratch the metal tank. This stuff will burn the skin if splashed on, so take precautions.
Don't put the stripper in a plastic container as it will eat a hole in it, a metal container will resist it the best.
  • MFolks
  • MFolks's Avatar
01 Nov 2011 15:18
#486505
These strippers come in two types; a water based, easy to rinse off, and one that requires solvent to remove. If it were me, I'd get the water rinse off type.
  • 750steve
01 Nov 2011 16:29
#486515
Thanks & im very well aware of how potent & dangerous this stuff is hence the post, i actually thought it would be too strong to use on the tank! It comes in a metal container & thats the way it's gonna be stored! I'm sure it melts nylon brushes etc so whats the best thing to use to scrape the paint with? Just use nylon & then dispose of them?
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • MFolks
  • MFolks's Avatar
01 Nov 2011 19:12
#486532
Cheap, bristle brushes work best for paint stripping as the Nylon ones will quickly melt in the stripper. Maybe a piece of sharpened Lexan or Plexiglass for scraping will hold up to the stripper.
  • ramtough_63
  • ramtough_63's Avatar
01 Nov 2011 22:28
#486590
got a tip from banshee used an old credit card worked real well. recently stripped the paint or powder coat on a wheel the gel stuff worked pretty well remember it is a chemical reaction and it doesnt make any difference if you leave it on longer than recommended it doesnt work any better usually 15-20 minutes.
Thought I would try leaving it on all day thinking longer is better. it made no difference worse if anything.
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • clutch
  • clutch's Avatar
01 Nov 2011 22:31
#486592
But it is sooooo quick, easy, and...relatively painless...LOL!
Wish List:
  • indianajames
  • indianajames's Avatar
07 Nov 2011 21:28
#487482
hey clutch, when you say frame "parts" do you meen frame itself and swing arm or somthin else?
