removing paint from chrome?
  • indianajames
  • indianajames's Avatar Topic Author
15 Oct 2011 10:58
#483318
rebuilding 77 650 , p.o. has painted entire engine black , including the chrome covers . i was just gonna coat every thing with gel paint stripper and use a nylon brush . will this hurt the chrome covers under the paint ?
  • z1kzonly
  • z1kzonly's Avatar
Re: removing paint from chrome?
15 Oct 2011 11:19
#483321
No, it will not hurt chrome at all.
After that use good ol' S.O.S. pads to clean up.
But it might darken your aluminum.
I always strip the clear laquer film off of stock engine covers and lower fork legs with stripper.
Because I am either polishing them or glassbeading them to paint or powdercoat.
Wear Eye goggles and rubber gloves when using stripper!!
Methylene Chloride stings and burns like hell.
Safety First!
  • Old Man Rock
  • Old Man Rock's Avatar
15 Oct 2011 11:32
#483324
Break fluid... Shit eats everything else up.... :pinch:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • indianajames
15 Oct 2011 12:11
#483333
do mean the aluminium block getting dark ? im gonna paint it . im talking about chrome covers . camchain , igniton ,clutch and such . these are chrome , not clear coated aluminium . sos wont turn it to brushed finish ?
  • wireman
  • wireman's Avatar
15 Oct 2011 14:14
#483344
take them to neighborhood carwash and strip em there,use the high pressure water to rinse stripper off so you dont scratch anything B)
The following user(s) said Thank You: indianajames
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
15 Oct 2011 20:24
#483397
If your 77 650 has the stock engine side covers, cam covers etc, they are not chrome, but rather polished aluminium. At least the ones on my 77kz650 B1 are.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • indianajames
15 Oct 2011 21:24
#483406
thanx every body , the covers are chrome , i guess from another year , anyhow , i got everything clean stripped on engine . it just the engine in the frame , blocked off intake and exhaust ports , soaked it down with gel paint stripper and power washed it , did this twice and its clean aluminium and chrome . except the chrome has some copper plating showing thru , sort of like someone polished it too much . but the head and jug finns and block look great.
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
15 Oct 2011 23:19
#483435
Old Man Rock wrote: Break fluid... Shit eats everything else up.... :pinch:
YEAH IT DOES! And it stinks when you don't intend to drip it on something! :silly:
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
  • WT100
  • WT100's Avatar
  • 1980 KZ 650
17 Oct 2011 23:25 - 17 Oct 2011 23:26
#483881
Oven cleaner does the trick on rattle can paint and as an added bonus won't even hurt plastic. B)
Let it soak in good and hit it with even a strong garden hose. Might take a few passes but you'l get there.
[IMG
100 Countries or bust, 74 so far!
Last edit: 17 Oct 2011 23:26 by WT100.
  • jydog
  • jydog's Avatar
18 Oct 2011 06:08
#483913
x2 on the oven cleaner. Im doing the same thing right now. You've got to let it sit for a while. Maybe and hour or two.
81 KZ1000 LTD
Griffin GA
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
18 Oct 2011 06:50
#483916
jydog wrote: x2 on the oven cleaner. Im doing the same thing right now. You've got to let it sit for a while. Maybe and hour or two.
All oven cleaners are not created equally...what brand of oven cleaner?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • jydog
  • jydog's Avatar
18 Oct 2011 10:56 - 18 Oct 2011 13:17
#483935
easy off
Im thinking mine is going to take about 5 of the small cans. I am also using a 3000 psi pressure washer
81 KZ1000 LTD
Griffin GA
Last edit: 18 Oct 2011 13:17 by jydog.
