Which paint for engine?
- austin3119
Re: Which paint for engine?
17 Nov 2011 02:10
Wow. That's crazy. Don't send them any money. Lol
I better go take a look in my garage real quick to make sure I haven't been robbed.
Got a link to the ad?
- Mariatyson
- I am a Tech Support Engineer.
18 Nov 2011 04:56martin_csr wrote: Not the engine, but I've painted the engine covers, wheels, muffler stays & brackets, and other parts w Duplicolor Engine Enamel w Ceramic. It comes in various colors, including black in gloss, semi-gloss, & low-gloss. I used semi-gloss black & baked the parts in the oven to cure. It has held up well - no chips or anything. As a side note, bar-b-que grill paint works good to deter rust on the back side of steel parts.
But I'd guess the VHT or something else is better.
Awesome efforts! The bike seems to be a new one.
Well done!
- gwolever
19 Nov 2011 22:42
Hey guys. Just thought I'd update. Got the engine polished, painted, and all back together again with new seals, gaskets, various mods. Pretty happy with it. Used the high temp engine paint on a few pieces. Only hope it holds up. Thanks for all the input.
Attachment 306.JPG not found
1982 KZ1000 CSR
19 Nov 2011 22:49
Engine is beautiful, a showpiece, and the hi-temp paint should hold up well, and be easily touched up if ever needed.
- KZJOE900
- Administrator
Super Users
19 Nov 2011 23:19
Looks like it's just off the factory assembly line. Only better! Good show!
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- MFolks
20 Nov 2011 00:22
Some parts can be baked in the oven at home(it might make a smell, so open the windows if possible)300-350 F for about 1 hour will make a durable paint job. I use short hooks made from wire coat hangers, with the parts to be baked suspended from the oven racks.
Items like engine covers and the sprocket cover can be baked, just remove any seals or pieces that can by damaged by heat(wires, & rubber parts).
The PJ-1 "Fast Black" is a close match to the black paint used on some of the Kawasaki engines.
- KZ250LTD
Last edit: 13 Feb 2012 17:47 by KZ250LTD.
- Zedone
20 Nov 2011 17:36
-Great looking engines gwolver, & Austin
-Nice bike Martin
The best way to paint crankcases/blocks/heads is to powder coat or Gun Kote them IMO. Using an oven will make them last alot longer. There is way too much work envolved to strip an engine to have to redo them.
Mfolks, do you really use your house oven to cure your parts in? Wow! Maybe I misread your post.
Doug
-Nice bike Martin
Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- cyclhed
22 Nov 2011 04:33gwolever wrote: I want to dot head and block with aluminum color and the rest in black (probably gloss instead of flat).
It is all off frame. Engine covers removed and polished.
I noticed that PJ1 on the Z1 site. Supposed to be close to factory type paint. Might try that for the black.
Thanks.
VHT Engine Metallic or VHT Caliper paint in the silver color works excellently for engines. It cures to a super durable finish after the engine is run the first time. Follow the directions on the can.
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
- 750steve
12 Dec 2011 21:19
So, anyone that has painted their engine & the finish has lasted
Did you.....
1/ Use an Etch primer?
2/ Did you bake your parts (& is this necessary?)
The reason i ask no 2 is because if im painting a complete engine i won't find an oven big enough, can a heat gun cure the paint?
Did you.....
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- DoctoRot
13 Dec 2011 23:33750steve wrote: So, anyone that has painted their engine & the finish has lasted
Did you.....
I used gun kote on my engine cases. It has yet to see any road time, but from just scraping at it with a screwdriver it seems pretty durable. I had the cases mediablasted with a 50/50 mix of granite and glass bead. No etch primer. Shot it, and baked it for 2 hours.
I would be very cautious if using a heat gun to cure the paint, as heat guns are primarily used in the removal of paint. if you have a decent heat gun it can get to 1200+ degrees, which would probably be enough to burn the gun kote. I just picked up a crappy oven on craiglist for $20, works great. If you don't have room for an oven, you could probably find a smaller powdercoating shop and see if they would let you cure your parts in their oven.
Also if you do use the gun kote, be aware that the black and green have lead in them. So probably don't wanna do that in the house... or be anywhere around the fumes...
- DoctoRot
13 Dec 2011 23:34 - 13 Dec 2011 23:39
Last edit: 13 Dec 2011 23:39 by DoctoRot.
