Which paint for engine?
- KZJOE900
- Administrator
Super Users
Re: Which paint for engine?
19 Nov 2011 23:19
Looks like it's just off the factory assembly line. Only better! Good show!
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- MFolks
20 Nov 2011 00:22
Some parts can be baked in the oven at home(it might make a smell, so open the windows if possible)300-350 F for about 1 hour will make a durable paint job. I use short hooks made from wire coat hangers, with the parts to be baked suspended from the oven racks.
Items like engine covers and the sprocket cover can be baked, just remove any seals or pieces that can by damaged by heat(wires, & rubber parts).
The PJ-1 "Fast Black" is a close match to the black paint used on some of the Kawasaki engines.
- KZ250LTD
Last edit: 13 Feb 2012 17:47 by KZ250LTD.
- Zedone
20 Nov 2011 17:36
-Great looking engines gwolver, & Austin
-Nice bike Martin
The best way to paint crankcases/blocks/heads is to powder coat or Gun Kote them IMO. Using an oven will make them last alot longer. There is way too much work envolved to strip an engine to have to redo them.
Mfolks, do you really use your house oven to cure your parts in? Wow! Maybe I misread your post.
Doug
-Nice bike Martin
Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- cyclhed
22 Nov 2011 04:33gwolever wrote: I want to dot head and block with aluminum color and the rest in black (probably gloss instead of flat).
It is all off frame. Engine covers removed and polished.
I noticed that PJ1 on the Z1 site. Supposed to be close to factory type paint. Might try that for the black.
Thanks.
VHT Engine Metallic or VHT Caliper paint in the silver color works excellently for engines. It cures to a super durable finish after the engine is run the first time. Follow the directions on the can.
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
- 750steve
12 Dec 2011 21:19
So, anyone that has painted their engine & the finish has lasted
Did you.....
1/ Use an Etch primer?
2/ Did you bake your parts (& is this necessary?)
The reason i ask no 2 is because if im painting a complete engine i won't find an oven big enough, can a heat gun cure the paint?
Did you.....
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- DoctoRot
13 Dec 2011 23:33750steve wrote: So, anyone that has painted their engine & the finish has lasted
Did you.....
I used gun kote on my engine cases. It has yet to see any road time, but from just scraping at it with a screwdriver it seems pretty durable. I had the cases mediablasted with a 50/50 mix of granite and glass bead. No etch primer. Shot it, and baked it for 2 hours.
I would be very cautious if using a heat gun to cure the paint, as heat guns are primarily used in the removal of paint. if you have a decent heat gun it can get to 1200+ degrees, which would probably be enough to burn the gun kote. I just picked up a crappy oven on craiglist for $20, works great. If you don't have room for an oven, you could probably find a smaller powdercoating shop and see if they would let you cure your parts in their oven.
Also if you do use the gun kote, be aware that the black and green have lead in them. So probably don't wanna do that in the house... or be anywhere around the fumes...
- DoctoRot
13 Dec 2011 23:34 - 13 Dec 2011 23:39
Last edit: 13 Dec 2011 23:39 by DoctoRot.
- 750steve
14 Dec 2011 15:58
Thanks for the advice! As im doing my engine complete & its a bit heavy to throw about i'll need to do it in house so i'll need to use my heat gun, it has a variable setting so i'll see what maximum & minimum is & set it somewhere that scales about right.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- Fritula
- holly land garage
15 Dec 2011 23:07Please Log in or Create an account to join the conversation.
- Fritula
- holly land garage
15 Dec 2011 23:13
Hey DoctoRot,there is some real work there.I love it.what paint you use. I got mine with PC1 Yamaha engine paint and bought it at Honda realer,haha.But lemi tell you I like black paint on engine more and more.Looks so good.Is this semi gloss.
- Samminorwich
16 Dec 2021 15:14
Hi how long does this soda finish last it must oxidize ?
