Duplicolor caliper paint - used it?
- otakar
Re: Duplicolor caliper paint - used it?
30 Jul 2011 17:10 - 30 Jul 2011 17:39
The ONLY coating impervious to DOT-3 is Gun-Kote By KG industries. Nothing else is. DOT-5 is safe with almost all paints but is not Hygroscopic and is intended to be changed often. If it is not than moisture will settle out of it and you will rot out your system. Motul-5.1 or "Valvoline Synpower" is synthetic and should work fine with most good quality enamels such as POR-15.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 30 Jul 2011 17:39 by otakar.
- Nelson
01 Aug 2011 02:18
Thanks otakar. good info.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
