Duplicolor caliper paint - used it?
- Nelson
25 Jul 2011 01:24
I notice Duplicolor makes a paint for calipers. I looked carefully at the label for "resistant to brake fluid" but that phrase is not on it.... It does say "chemical resistant."
I have a hard time believing anything from a spray can will not be attacked by brake fluid.
Anyone tried it? I was thinking of using it on calipers and wheels also so they match.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
Last edit: 15 Feb 2013 10:57 by martin_csr.
- Nelson
Re: Duplicolor caliper paint - used it?
25 Jul 2011 22:36
just as I suspected. thanks much!
- testarossa
25 Jul 2011 23:45
Never used the Dupe caliper paint, but brake fluid will eat up 2 part clear coat. If it gets through that stuff then rattlecan paint doesn't stand a chance. I wonder how well that Gun Cote (sp?) would hold up on some calipers? Maybe you could send a pm to Otakar. He's the resident expert on that stuff.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- boyracer
29 Jul 2011 06:33
Painted mine with primer/hi-fill then same enamel paint as bike....wet sanding and all, about 8 coats i remember. That was 20 years ago and am currently stripping this off to refinish 'em again. Only neglect by interim owner caused crazing/lifting.
- 0Z.Z1R Mk2
29 Jul 2011 08:40
Don't want to get into a debate over brake fluids...
But I'm glad I used dot 5 on my project,otherwise there'd be no paint left on it.:whistle:
Did I mention how I hate bleeding brakes?
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
Last edit: 22 Jan 2013 05:06 by martin_csr.
- Jeff.Saunders
29 Jul 2011 09:22
Anytime I totally rebuild the caliper and master cylinders, I refill with dot 5. Primarily because for the paint stripper feature of dot 3 fluid.
I do flush the dot 5 fairly frequently - every year or two.
- boyracer
29 Jul 2011 10:39
...probs best to just not get brake fluid everywhere! I use clear (1/4"?) hose ziptied to nipple then into a bottle of clean brake fluid for trouble free bleeding. I used generic auto paint,properly dry between coats, not premix/rattlecans. I have painted lots of small cycle stuff with dupli over the years though, same rules and it works a treat.
- Nelson
30 Jul 2011 00:38
I can't imagine bleeding brakes without getting ANY fluid around the bleeder area... If I try really hard I could keep it pretty clean, but there's gonna be some fluid on the caliper.
30 Jul 2011 01:32
Length of clear tube snugly fitted onto the bleeder keeps fluid off caliper.
Direct the waste fluid into a catch bottle.
After bleeding, spray common household rubbing alcohol over the caliper to douche the caliper and rinse off any brake fluid residue. Then blow with compressed air if available.
A 50ยข plastic bottle of rubbing alcohol with a spray attachment is a handy work bench item.
- Nelson
30 Jul 2011 13:25
yeah yeah I knew somebody would chime in and tell me how... :lol:
Even so, there's usually just a bit of leakage around the threads of the bleeder. I spose if the paint is fully cured and u clean if off quick it might be OK.
