Duplicolor caliper paint - used it?
  • Nelson
  • Nelson's Avatar Topic Author
25 Jul 2011 01:24
#464714
I notice Duplicolor makes a paint for calipers. I looked carefully at the label for "resistant to brake fluid" but that phrase is not on it.... It does say "chemical resistant."
I have a hard time believing anything from a spray can will not be attacked by brake fluid.
Anyone tried it? I was thinking of using it on calipers and wheels also so they match.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
  • martin_csr
  • martin_csr's Avatar
Re: -
25 Jul 2011 09:34 - 15 Feb 2013 10:57
#464753
Last edit: 15 Feb 2013 10:57 by martin_csr.
  • Nelson
Re: Duplicolor caliper paint - used it?
25 Jul 2011 22:36
#464919
just as I suspected. thanks much!
  • testarossa
  • testarossa's Avatar
25 Jul 2011 23:45
#464948
Never used the Dupe caliper paint, but brake fluid will eat up 2 part clear coat. If it gets through that stuff then rattlecan paint doesn't stand a chance. I wonder how well that Gun Cote (sp?) would hold up on some calipers? Maybe you could send a pm to Otakar. He's the resident expert on that stuff.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • boyracer
  • boyracer's Avatar
29 Jul 2011 06:33
#465659
Painted mine with primer/hi-fill then same enamel paint as bike....wet sanding and all, about 8 coats i remember. That was 20 years ago and am currently stripping this off to refinish 'em again. Only neglect by interim owner caused crazing/lifting.
  • 0Z.Z1R Mk2
  • 0Z.Z1R Mk2's Avatar
29 Jul 2011 08:40
#465663
Don't want to get into a debate over brake fluids...
But I'm glad I used dot 5 on my project,otherwise there'd be no paint left on it.:whistle:
Did I mention how I hate bleeding brakes? :angry:
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
  • martin_csr
Re: .
29 Jul 2011 09:16 - 22 Jan 2013 05:06
#465666
Last edit: 22 Jan 2013 05:06 by martin_csr.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
29 Jul 2011 09:22
#465668
Anytime I totally rebuild the caliper and master cylinders, I refill with dot 5. Primarily because for the paint stripper feature of dot 3 fluid.
I do flush the dot 5 fairly frequently - every year or two.
  • boyracer
  • boyracer's Avatar
29 Jul 2011 10:39
#465681
...probs best to just not get brake fluid everywhere! I use clear (1/4"?) hose ziptied to nipple then into a bottle of clean brake fluid for trouble free bleeding. I used generic auto paint,properly dry between coats, not premix/rattlecans. I have painted lots of small cycle stuff with dupli over the years though, same rules and it works a treat.
  • Nelson
30 Jul 2011 00:38
#465791
I can't imagine bleeding brakes without getting ANY fluid around the bleeder area... If I try really hard I could keep it pretty clean, but there's gonna be some fluid on the caliper.
30 Jul 2011 01:32
#465798
Length of clear tube snugly fitted onto the bleeder keeps fluid off caliper.
Direct the waste fluid into a catch bottle.
After bleeding, spray common household rubbing alcohol over the caliper to douche the caliper and rinse off any brake fluid residue. Then blow with compressed air if available.
A 50ยข plastic bottle of rubbing alcohol with a spray attachment is a handy work bench item.
Good Fortune! :)
  • Nelson
30 Jul 2011 13:25
#465844
yeah yeah I knew somebody would chime in and tell me how... :lol: ;)
Even so, there's usually just a bit of leakage around the threads of the bleeder. I spose if the paint is fully cured and u clean if off quick it might be OK.
