exhaust repaint need help!
  • vettezr1262
  • vettezr1262's Avatar Topic Author
21 Jun 2011 00:57
#458457
My KZ550 Spectre had rusty pipes, so I took them off, I'm in the process of sand blasting them, then I want to repaint them the original gloss black....I read up on this high temperature paint for headers (my biggest concern on the exhaust system) and almost everyone has trouble with any of the "High Temperature" header paint. So should I turn to cerarmic powder coating? and roughly how expensive is it? I want a practical solution that won't blow my money on this bike.
1983 KZ550 Spectre (in progress)
  • Chaotic Reason
  • Chaotic Reason's Avatar
Re: exhaust repaint need help!
21 Jun 2011 01:50
#458467
Michael
1980 KZ1000 shaft drive
  • supercharged
  • supercharged's Avatar
21 Jun 2011 04:02
#458480
i have used hi-temp paint mostly engine satin - even a little in gloss black with no issues.
I like the ceramic much better as it is more resistant, but at a cost. I think I paid $250 for my 4-1 (just coating)
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
  • DoctoRot
  • DoctoRot's Avatar
21 Jun 2011 19:06 - 21 Jun 2011 19:07
#458603
You might wanna try using some metal prep etch, Sherwin-Williams makes some and its awesome. sandblasting will prep the surface adequately for most paint, but if it is in a high heat area I would etch it with the acid as well. It chemically prepares the metal to receive paint. Any good powdercoating place will do this even if it has been sand-blasted before, but if your looking for real durability there's nothing better than sweet sweet powder coat B)
Last edit: 21 Jun 2011 19:07 by DoctoRot.
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
22 Jun 2011 01:01
#458675
If you are sand blasting them (not soda, walnut, etc.) then the surface will probably be a little rough for the gloss black you want to use. Flat or satin might be the way to go.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
  • Jaxx
  • Jaxx's Avatar
25 Jun 2011 00:35
#459233
If your talking exhaust, powder is not the way to go. I work in a powder coating shop and powder is not rated for anything over 410f, which I am sure your pipes will reach time and time again. Plus powder coating will hold in the heat causing your engine to run hotter than optimal. Best bet for a high gloss finish that will last and actually help disperse the heat is cermakrome ( not a powder ).
When we do exhausts we use 120grit aluminum oxide sand in our blasters, which leaves a nice smooth surface on the metal. We then put a base coat of MCX ( which is rated for 1200F and acts the corrosion resistance barrier), bake that at 600f for 2 hours. We then etch that coating with the aluminum oxide at 40-50psi, then apply 2 coats of 2000degree black, flashing off in between coats at 400f for 1 hour, then bake at 650f for 2 hours. Then to achieve the gloss, we do 2 coats of cerma-seal, which is an airdry coating.
We have never had any problems or complaints. As for price on a 4 into 1, it will vary depending on the pipes and condition but in the range of $225-250.
JetHot is one company that sells exhaust coating. We use Tech-line Coatings in the shop.
Hope this helps.
The following user(s) said Thank You: jeffwerner
  • MFolks
  • MFolks's Avatar
25 Jun 2011 01:12
#459240
Many years ago(more than I care to think about), I purchased a Kerker K2S for my 1982 GPz1100. Being the supplied paint was burning off and rust was showing through, I asked around the bike shops for what they did in my situation. To a person, the name "Flame Spray" was mentioned.
I lived in San Diego at the time, and their shop was close by. They first blasted the old paint off, and then sprayed on an Aluminum coating. I then used a high temperature black header spray as a final covering. No engine overheating has been found, an except for an occasional touchup from road debris, it's been maintenance free.
www.flamesprayinc.com/companyinfo.htm
  • Linsk
  • Linsk's Avatar
  • Ron L
25 Jun 2011 03:34
#459253
I had my kerker done about 20 years ago buy jethot when they had a three day turn around. It cost me 120 back then best thing i did. I use to sand blast my header once a year and paint it never lasted. They coat inside and out runs cooler.After 20 years it starting to get thin in some areas. Some rust is coming through. Going to get it redone this winter there turn around is alot longer now and more expensive but worth it.
1980 KZ 1000 A4 1075 kit 1980 KZ 1000 st 2400 orig miles 1982 GS 1100 E sold 2017 ZX 14R
  • Linsk
  • Linsk's Avatar
  • Ron L
25 Jun 2011 03:54
#459254
If you go to the gallery kz1000 sec page 102 image 1528 titled hibernation there is a good pic of my kerker header after 20 years of riding with a jethot coating. you can get black too.
25 Jun 2011 08:51
#459268
:unsure: Image 1527
  • hocbj23
  • hocbj23's Avatar
25 Jun 2011 10:23
#459275
Just had a local shop ceramic coat my Kerker for my Radian.They used a satin black and did the pipes inside and out.Looks great and the pipes actually run cooler.150 bucks.bj
  • vettezr1262
14 Jul 2011 17:33
#462859
Alright thanks guys. This is basically just a selling point but I'm planning on riding this bike about 1/2 a year before selling it. So if there is a much less expensive way that will last only this short amount of time, that is what I'd prefer. I'm still working on blasting them...I'm now avoiding it in this terrible heat but I was planning on then using the claimed 2000 degree F high-temp spray paint. I have to say I do not believe that whatsoever but like I said, I want a cheap fix for my poorly taken care of pipes.
