Z1 Frame Paint?
  • s3steve
  • s3steve's Avatar Topic Author
Z1 Frame Paint?
11 Mar 2011 09:14
#437043
What brand do you guys recommend.
Satin or gloss finish?
Epoxy or ?
Prime first?
What's the best match to factory paint?
Thanks!!!
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Z1 Frame Paint?
11 Mar 2011 10:34 - 11 Mar 2011 10:38
#437059
The factory paint was non-primer semi gloss black. It could have been gloss black but Kawi put a half-ass finish on them so the final result was more semi-gloss. Personally, I like PJ1 Fast Black epoxy paint. It has a finish that resembles a factory finish without looking like a Rustoleum spray-bomb job. Works great on other black components and switch housings too.
Here's some pics:
Frame
Battery box, helmet hooks, etc
Switch housings
I made a write-up on the switch housings over on Z1OC. If you're starting with sand blasted parts like I did, you'll need 4 cans to do a complete Z1. Frame, swing arm, and all the misc parts. PJ1 doesn't recommend a primer for this paint.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 11 Mar 2011 10:38 by Kidkawie.
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
Re: Z1 Frame Paint?
11 Mar 2011 12:10
#437066
Powdercoat it- you'll get a much more durable finish.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Z1 Frame Paint?
11 Mar 2011 12:36
#437070
You can't PC a frame and retain the original VIN decal.
1975 Z1 900
2004 KX125
  • stonemaster
  • stonemaster's Avatar
Re: Z1 Frame Paint?
11 Mar 2011 12:48
#437072
and its not significantly more durable wither, it will chip too.
  • wireman
  • wireman's Avatar
Re: Z1 Frame Paint?
11 Mar 2011 12:52
#437073
does anybody have a source for duplicate steering head stickers? B)
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Z1 Frame Paint?
11 Mar 2011 12:58
#437075
Yours truly. But I haven't found a donor yet. There's a long thread on Z1OC.
1975 Z1 900
2004 KX125
  • s3steve
Re: Z1 Frame Paint?
11 Mar 2011 12:58
#437077
A couple of things I don't like about PC is it hides frame cracks and it's not easily repaired. It does look great and it holds up well but on a '73 I'd like to keep it as close to original as possible.
RB the triple king can get a VIN sticker for you.
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
  • racer54
  • racer54's Avatar
Re: Z1 Frame Paint?
11 Mar 2011 18:30
#437160
What is Z1OC? Can you show a shortcut to it?
  • TIKI
  • TIKI's Avatar
Re: Z1 Frame Paint?
11 Mar 2011 23:02
#437224
1973 Z1900 Santa Rosa,CA
  • TIKI
  • TIKI's Avatar
Re: Z1 Frame Paint?
11 Mar 2011 23:12
#437225
Ok so disregarding powder coating and any brand of rattle can what would you use, I’m ready to buy a spray gun and step up to good durable automotive type paint.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Z1 Frame Paint?
13 Mar 2011 07:07
#437619
Tiki, for the KX Im restoring I sprayed the frame with a single stage urethane from an auto paint supplier. It cost $125 for a pint of paint, catalyst and reducer. Im using a cheap $20 detail gun off Ebay. Got great results but to match an original Z you may want the shop to cut down on the gloss.
1975 Z1 900
2004 KX125
