Z1 Frame Paint?
- Old Man Rock
Re: Z1 Frame Paint?
13 Mar 2011 08:11 - 13 Mar 2011 08:17
I tried many various frame designed paints and none of them held up well as Dupli-Color Wheel base paint...
Downfall... Limited colors...
www.duplicolor.com/products/wheelCoating/
Wheel Coating
Customize or dress up worn out wheels with Dupli-Color® Wheel Coating. This advanced, track-tested acrylic enamel formula restores original wheel appearance and protects against brake dust, chemicals, cleaning solvents, heat, and chipping. Dupli-Color Wheel Coating features a highly reflective metallic finish with superior adhesion to steel, aluminum, and plastic wheels and wheel coverings.
Wheel Coating
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 13 Mar 2011 08:17 by Old Man Rock.
- TIKI
Re: Z1 Frame Paint?
15 Mar 2011 23:03
Thanks Kid, the green looks good, I've used PJ1 myself and like it as far as rattle cans go.
1973 Z1900 Santa Rosa,CA
- mtbspeedfreak
Re: Z1 Frame Paint?
19 Mar 2011 20:04
Keep us posted! You mind snapping a few pics of the finished product?
2000 ZRX 1100
1976 KZ 900- Daily Driver
- marcuch
Re: Z1 Frame Paint?
26 Mar 2011 01:05 - 26 Mar 2011 01:06
Regarding the steering head stickers. Carefully remove the label..CAREFULLY. Scan it. Bring it to a print shop so they can print it on white vinyl. I've only heard of one guy that found a material that was almost an exact match to the OEM. He had to get it from a relative in the Netherlands. Good luck!
Last edit: 26 Mar 2011 01:06 by marcuch.
- Kidkawie
- I bleed premix
Re: Z1 Frame Paint?
27 Mar 2011 13:47marcuch wrote: Regarding the steering head stickers. Carefully remove the label..CAREFULLY. Scan it. Bring it to a print shop so they can print it on white vinyl. I've only heard of one guy that found a material that was almost an exact match to the OEM. He had to get it from a relative in the Netherlands. Good luck!
The Z1 decals are not on white vinyl. It's a paper label with a clear packing tape-type protector over it.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- nysz1b
Re: Z1 Frame Paint?
16 Jun 2011 13:43
Would that be PJ1 Fast Black semi-gloss, or gloss black? Thanks.
