clear coating brushed metal gas tank?
  • crd
  • crd's Avatar Topic Author
18 Apr 2006 13:30
#40567
I like the brushed metal look. Is it a bad idea to remove the paint on the gas tank of my KZ250 project by wirewheel and steel wool and then apply a clearcoat to prevent rusting?
Post edited by: crd, at: 2006/04/18 16:31
  • BARNEYHYPHEN
  • BARNEYHYPHEN's Avatar
Re: clear coating brushed metal gas tank?
18 Apr 2006 13:45
#40569
Sounds good to me. The only possible downside is whether or not the clear coat will adhere sufficiently well to the bear metal? Mark Wing might know the answer?
  • securitygeek
  • securitygeek's Avatar
18 Apr 2006 17:00
#40603
how about applying a clear primer first? Such as Duplicolor Adhesion Promoter
  • btchalice
  • btchalice's Avatar
18 Apr 2006 17:02
#40605
i had to do it barney i couldnt resist is do they skin one of these for bear metal?
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • KL250
  • KL250's Avatar
18 Apr 2006 17:41
#40614
I would go for the clearcoating. a good automotive grade clear (NOT SPRAY CAN) will adhere well enough. I wouldn't sand it any finer than about 320 though. the corrosion protection probably wont be very good but it will certainly be better than wax. come to think of it i belive that ppg has a clear primer surfacer that might help the adhesion. You could also have it powder coated, any of these should work, but i would certainly stay away from the spray can stuff.
  • fonZee
  • fonZee's Avatar
18 Apr 2006 18:34
#40626
crd wrote:
I like the brushed metal look. Is it a bad idea to remove the paint on the gas tank of my KZ250 project by wirewheel and steel wool and then apply a clearcoat to prevent rusting?<br><br>Post edited by: crd, at: 2006/04/18 16:31
I do it all the time. It can be done. First off,clean the metal parts after you have brushed or grind them. Use House of Kolor adhesion promoter. I will get the part number for you if needed. Let it dry and clear away. On some custom paint work we also put candy in with the clear giving it a colored affect. Looks great !
  • KzJim
  • KzJim's Avatar
18 Apr 2006 19:11
#40638
Powder coat it... it will stick no prob... the clear i use is UV and fuel resistant.... if ya havent done anything to it yet.. i'd be happy to do it for a few bucks + shipping...
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
  • crd
18 Apr 2006 20:16
#40674
Thanks guys. KZJim, I may just take you up on that down the road. However, I need to get this up and running first before I start making it look purty. :-)
  • donthekawguy
  • donthekawguy's Avatar
18 Apr 2006 23:53
#40746
I saw a show on DIY where they stripped the paint off of a VW Jetta and took a grinder to the roof and made dsigns on it. They clear coated it and it looked killer.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Fossil
  • Fossil's Avatar
19 Apr 2006 00:17
#40759
I stripped and allowed to slightly rust, a cromoly BMX dirt jump frame and flat clear coated for my son years ago. Halted the rust process and it stood up quite well, looked nasty too. Just used an automotive spray can clear.
  • KL250
  • KL250's Avatar
19 Apr 2006 10:03
#40849
I'd imagine that the spray can stuff will hold up well enough, i suggested the good stuff becuase it would be more gas resistant.
  • fonZee
  • fonZee's Avatar
19 Apr 2006 10:05
#40851
The product to use is House of Kolor AP-01. It is the adhesion promoter I mentioned earlier. Then simply clear coat over that. I would use an automotive catalyzed type clear though.
