Paint for the engine?
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
05 Oct 2010 17:19
#404323
What is the best kind of paint for painting an engine? How do i apply it so it holds up without peeling and chipping? Or could i have the parts powder coated? Thank's, Jim.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Paint for the engine?
05 Oct 2010 17:49 - 05 Oct 2010 17:49
#404332
i sanded the flat surfaces and polished em....wire brushed all the nooks ,fins,cranny's......sprayed the whole thing with fast flash off parts cleaner and an air nozzle to blast out tiny spots,wiped it with clean rags...taped the stuff that needed protecting..even the tiny screw and nut heads......then blew it all off again with air and wiped what was exposed again.....i used thin coats of duplicolor high heat satin black engine paint and repeated em after a few hrs dry time...the next day i wiped it down and gave it an even thin coat...it came out super nice.......
(youtube)
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 05 Oct 2010 17:49 by trianglelaguna.
  • trianglelaguna
05 Oct 2010 17:53
#404337
i had to sand the fins and fine art brush a few tiny tape show spots...it will pass for super clean up close no problem.....took 2 hrs and cost 25 bucks..cleaner,tape and paint
1976 KZ900
2003 ZX12R
2007 FZ1000
  • z1kzonly
  • z1kzonly's Avatar
05 Oct 2010 17:53
#404338
Depends on color Jim.
I myself always liked a gloss black for the Z1-KZ engine.
Gloss is hard to find. I like PJ1.
If you you want flat or satin there are plenty of paints out there. VHT, plastic coat wood stove paint, good to 1500 degrees.
1st, is your engine a rebuild? Cleaned? On the bench?
Or in the bike still?
I media blasted my cases years ago with aluminum oxide, then cleaned and cleaned again. always screw the screws into all holes when blasting.
Right before painting, I put lacquer thinner in a spray gun and just sprayed the heck out of the engine with clean thinner and let it evaporate. I also used a hand held propane torch, (WELL AFTER IT DRIES)!! And warm the aluminum, you can see the moisture coming out. Then it is ready to paint.
If you have a big enough oven, you can help cure the paint by baking it. Don't use your kitchen oven if your married! LOL!
Side covers, cam cover etc. can be powder coated easy and cheap. My next engine, I'm gonna powder coat the side covers black, with all stainless screws!
  • oldkaws4ever
05 Oct 2010 18:13
#404348
I really want to do the glossy black, it look's so good. It will be on the bench in the next couple week's as i am going to throw in new rings and such. I like the idea of the gloss black side and cam covers with stainless screws. Craig i love the MK-2 engine it looks killer, ill keep it in mind when i start tearing into mine. Il make sure to post lots of pics :)
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • TerryK
  • TerryK's Avatar
05 Oct 2010 20:01
#404382
Use PJ1 high temp engine paint in semi gloss. You'll love the finish and it will last a long time.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • oldkaws4ever
05 Oct 2010 23:54
#404412
Should i clear coat it too?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • stonemaster
  • stonemaster's Avatar
06 Oct 2010 05:38
#404426
VHT makes a good product as well
  • kz1k
  • kz1k's Avatar
  • You Cant Fix Stupid!
06 Oct 2010 06:37
#404438
i was under the impression that paint will not let a motor breathe.
1978 KZ1000A2
  • Oliver
  • Oliver's Avatar
06 Oct 2010 07:42
#404450
The wrong kind of paint, like a high heat enamel seals the pours in the aluminum casting preventing the engine from dissipating heat as it was designed. (this was discussed in the thread"engine finishes")
PJ1 is the only paint I would use on an "air cooled" engine
The Dupicolor high heat engine enamel is designed for water cooled engines not air cooled engines.
Things I currently own
1983 kz550ltd owned 10 years
1982 kz1100a2 just bought as winter project
1967 vw beetle 1775cc first car owned 25 years
  • kz1k
  • kz1k's Avatar
06 Oct 2010 07:57 - 06 Oct 2010 07:58
#404452
what about the people who dont want a black engine? imo the bare aluminum look is the sexiest look for a bike motor. once the painted engine is cleaned and bare aluminum, how can you protect it from oil, grease, and the elements?
1978 KZ1000A2
Last edit: 06 Oct 2010 07:58 by kz1k.
  • Oliver
  • Oliver's Avatar
06 Oct 2010 08:14
#404453
To expand on what I'm saying.
Painting your engine with the wrong paint will cause it to wear faster, It generally won't lock up a bike, but if you know what damage to look for, you will see it.
It will cause you engine to run hotter than it should. That might actually be a good thing if you are in a cooler climate, kind of like putting a cover on the radiator of a semi.
But you run that engine in a hotter climate and that's where you do the damage.
Painting your engine with the wrong paint can or will cause the following problems..
warping the head
cracks in the head
early failure of the oil return seals between the head and cylinders
chrome on the exhaust tarnishing faster or the paint finish rusting out faster.
burnt pistons and rings.
stuck valves
blown head gasket
breaks your oil down much faster
10k to 20k less miles before a rebuild.
and probably other things that I have not seen first hand.
If you already painted your engine, I'm not trying to bust your balls. I am simply giving you information I have found over the past 25 years building engines.
If you have already painted your engine. I wouldn't remove or do anything with the paint. just be aware of the possibility of running to hot while stuck in traffic, change your oil sooner and keep an eye out for leaks between the head and the cylinders.
