changing color of emblems
- Topper
13 Sep 2010 17:28
Anybody ever tried to change the colors of the stock emblems on a KZ? In particular I'm looking at badges like this:
Mine have been (badly) painted over. Instead of ordering replacements, I'm thinking about trying to change the original colors by stripping off the bad paint and repainting them.
Anybody else done this? Got some pics?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- TeK9iNe
- What did you do!?!
Re: changing color of emblems
13 Sep 2010 18:11
I dont have pice, but I have done this many times.
Most poplular is just spraying it gloss black, then lightly block poliashing it to reveal the raised metal areas only.
Looks sharp...
Good luck.
Looks sharp...
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- kzbobber1
13 Sep 2010 18:36
if you are wanting them a specific color than you need to strip them and find a good pin striper or sign painter and they can do them any color you want. or you could spend alot of time masking them out.
- PLUMMEN
13 Sep 2010 18:40
- Topper
13 Sep 2010 18:51 - 13 Sep 2010 18:55
I've kind of got a combination of these ideas in mind. I want them black and the raised parts silver. I find the gold kind of limiting in creating color schemes.
I've stripped one and am going to spray it black, then try and paint the high parts silver with a paint pen. Then finish it with some clear to protect it a little.
1979 KZ750 Twin
1979 KZ750 Twin
Last edit: 13 Sep 2010 18:55 by Topper.
- PaintWorkz
14 Sep 2010 03:16
I have done the aluminum tank emblems buy carefully stripping old paint out of the inside of the lettering, puddling in a couple coats of new paint with a brush all the way up on to the silver edge, after a couple hours trim off slopped over edge paint with a fresh X-acto blade held flat/parallel to emblem. If redoing the black use thinned out S.E.M. Trim Black and the same process.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
- H1Vindicator
Last edit: 21 Feb 2013 20:50 by H1Vindicator.
- apbling
14 Sep 2010 07:34
Any pictures would be awesome... I've been thinking of painting my 82 550 tank and side cover emblems black and maybe doing some silver outlining...
My tank emblems don't seem to be painted though...the metal finish seems to be a polished gold color...?
- angel_uk
- Wildlife Artist and adventurer by any means!
14 Sep 2010 07:43
hi there
i scanned mine in and produced some photos.
you could laminate them and glue them on?
seriously i've just repainted mine. i masked them off and hand painted with a very fine brush with two part caliper paint in gloss black!.
best wishes
angel
best wishes
angel
- jayw704
14 Sep 2010 08:04 - 21 Oct 2010 21:35
Now I didnt change the color I just redid the original white and black but I just got as much of the old off as possible then taped over the emblem and cut out the area to be painted then some good old duplicolor rattle can light coats a couple times then scrape the top edge with a razor. Had to go back and make some minor touch ups with a brush but all in all very cheap and quick way of doing it at home.
1978 KZ1000
Go Loud and go fast or dont go at all!!!
Last edit: 21 Oct 2010 21:35 by jayw704.
- Topper
14 Sep 2010 08:33
Those are great pics. Can you tell us a little about each of these photos and what phase each of these are in?
1979 KZ750 Twin
1979 KZ750 Twin
- jayw704
14 Sep 2010 09:06
The first one is cleaned and taped over and cut off the tape left the letters covered for the black background. The second is tapped over again and cut out the inside of the letters and painted white. The third is first pull off of the tape no touch up or scrapping done yet. But about 5 minutes with a straight razor on the bare metal areas and a couple of dots of touch up in a couple areas. All in all not too much work just the time for the paint to dry.
1978 KZ1000
