Fairing replacement
- johnny chop
Fairing replacement
15 Apr 2006 18:08
Bought this fairing and while installing it the wrap around plexiglass cracked. Well actually I dropped it wile installing it.. :blush: Anyone know of a place where I can find replacement plexiglass?? Just the plexiglass....
Post edited by: johnny chop, at: 2006/04/15 21:10
Post edited by: johnny chop, at: 2006/04/15 21:11
- rstnick
Re: Fairing replacement
15 Apr 2006 19:02
I'd like to learn how to make my own, bend it and such, as mine has a crack as well.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- typhoon
16 Apr 2006 01:44
You can make a mould of your old screen. Remove your screen and tape it up or use whatever means you ned to, to get it back together again. You want to make sure the inside is smooth, as you will be making a male mould.
Now you can use a mould release agent on the inside of the old screen. cut some plywood or similar to dam off the end of the screen and pour in some expanding foam, or if you want to make a few, you can laminate fibreglass on teh inside of teh old screen.
Let whatever you used as a mould set, then remove it and clean up the edges. Now you want to glue some nice soft material like a synthetic suede or whatever to the outside of teh mould, so your perspex wil not mark up.
Grab some 4x2 timbers that are shorter than the width of your new mould and attach them onto teh base of teh mould. This will allow you to wrap the new plastic around and have it run off the edge of your mould easily.
Then you can greb a piece of plastic (lexan or perspex) heat it in teh oven, if it fits, if not, a large heat gun wil work, but is slow. If using an oven, place teh plastic on a tray, with some sort of high temp soft material unde rit (leather works O.K) You want teh oven not too hot, but hot enough so that you can bend a corner of teh perspex sheet up easily.
Heat it till it goes soft, but not to soft and drape it over the mould fairly quickly. It helps to do this with an assistant for teh first time. Have them ready with a heat gun to aim at stubborm bits.
Run a marker pen around the base of teh mould, remove plastic from mould and trim carefully with a fine hacksaw blade, or a bandsaw if you have access to that luxury.
Your first couple may stuff up on you, but hey, they end up being very cheap!
Regards, Andrew.
Post edited by: typhoon, at: 2006/04/16 04:52
Regards, Andrew.
gpzrider.com/
For all your air/liquid cooled GPZ fun!
- johnny chop
18 Apr 2006 09:37
Thanks.....but I think I'll just get some black duck tape for now.......JC
- Vter Bob
18 Apr 2006 10:17
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
- mariozappa
18 Apr 2006 11:24
Looks like a viper fairing.
You can get a replacement shield here.
www.crc2onlinecatalog.com/windsh_universal.htm
1977 KZ650C1
and the KZ650/KZ750 Conversion
- johnny chop
18 Apr 2006 20:54
mariozappa wrote:
Thanks.....JC
:woohoo: :woohoo: :woohoo: That looks like the one...Looks like a viper fairing.
Thanks.....JC
