shining that ugly metal
- AnxiousCowboy
22 Jul 2010 22:14
I'm pretty sure that the metal in aluminum, so I googled a bunch of how tos to polish up aluminum. I see a lot of them spraying the surface with oven cleaner before wet sanding. Is this necessary? I'd love to get this thing shinier!
As you can see it's looking pretty sad, especially against my shiny new mufflers....
- AnxiousCowboy
- TeK9iNe
- What did you do!?!
Re: shining that ugly metal
22 Jul 2010 22:25
Getting it nice and clean is easy. Rim cleaner and a power washer.
Getting it all shiney takes lots of patience and long hours of constant maintenence.
For the relatively flat stuff (and smaller areas with the right tip), I like a dremel tool with a polishing wheel. Just smother the part with mothers polish, then rub it down with the polishing wheel on around 2000rpm srtting until it dissapears and leaves a mirror finish.
Just dont nick anything with the dremel shank, as it will leave a permanent mark in the metal.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- AnxiousCowboy
22 Jul 2010 22:44
So wet sanding by hand with the different grits is not an option,I only want to do the area with the contact breaker cover....
- 9am53
- homebrew, and some bbq
23 Jul 2010 04:20
lots of people wetsand it, make sure you get up to a really fine grit, then use a good polish after that. Keep in mind, once you polish it up really nice, it will start oxidizing right away, so to keep it nice you will have to polish it once a week.
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- Old Man Rock
23 Jul 2010 04:48
Maybe this will help....
Buff-Book:
kzrider.com/index.php?option=com_docman&...d&gid=427&Itemid=108
Worked for me....
For the most part.... Tripoli then White Jewelers compound on a drill buff pad....
Buff-Book:
Worked for me....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
23 Jul 2010 07:15
hey whats that on the end of your finger? :laugh:
23 Jul 2010 07:35
- H1Vindicator
Last edit: 20 Feb 2013 20:28 by H1Vindicator.
- blue75kz900
23 Jul 2010 08:01
I have used Autosol. It's a paste in tube. It removes all the old tarnish and then leaves an inhibitor to prevent more oxidization. It won't get rid of pits but does a great job. I put it on using a rotory toothbrush.
I thinks it's at www.autosol.com .
My bike hasn't oxidized since.
Blue 1975 KZ900
Gold 1970 Chevy Nova 427...Bike killer
23 Jul 2010 08:16
H1Vindicator wrote:
Correct! In fact the instructions on oven cleaner cans say it should not be used on aluminum. Ed
I wouldn't use traditional oven cleaner containing sodium hydroxide - it's kinda corrosive. Sodium hydroxide is also called caustic soda. It's used to etch aluminum.
- Jack
23 Jul 2010 08:23
Used 'em all, Mothers, Simichrome, Autosol, Neverdull and on and on... The absoute best product I've found is Ragman's Polish, met the guy at a race at Norwalk last year. The chrome shop that helps me with my bikes liked it so much, it's the only polish they use now & ordered a case.
www.ragmansmetalpolish.com . Works on aluminum,chrome and even chromoly and the best part is if your stuff is clean it takes about 1/3 of the effort to keep it clean after using his polish.
Used it on these:
The TF bike is acres of polished aluminum and an uncoated but highly polished chromoly frame/ wheelie bars.Ragman's polish keeps the oxidation way way down.
Used it on these:
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
