shining that ugly metal
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: shining that ugly metal
23 Jul 2010 09:51
#384915
For parts you can easily remove you can make a polishing station out of an old electric motor. During the restoration process on my Z1 I found that a med-fine wire wheel on a pneumatic tool removed alot of the oxidation and polished the aluminum a little. It worked great for getting between the fins on the engine. I then used the aluminum polishing kit ($30 from Eastwood's) with tripoli followed by 0000 steel wool and finally some sort of metal polish. NOXON worked the fastest but leaves alot of black film. To remove that film I sprayed a terry cloth with WD-40.
Now that the bike is nearly done, I'll maintain it with Mothers.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • Gman
  • Gman's Avatar
24 Jul 2010 06:55
#385223
On my polished aluminum parts, I apply a coat of quality wax after I'm done buffing to keep it from oxidizing. This seems to work very well to keep it looking good. I just give it a light re-buff once a year and then wax again. This keeps it very low maintenence. Keep in mind if you clean the bike with any harsh cleaner that can strip off the wax (S100 for example), you will have to re-apply the wax.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
  • Kawickrice
  • Kawickrice's Avatar
24 Jul 2010 08:21
#385238
A drill motor and some buffs with some polish will do wonders. I use the drill if the parts are on the bike, I use the bench grinder from above if the parts are removed
This is a bag of soda and cheap guns for blasting the rough areas like the jugs and head
Before
After
You will need one of these because it is time consuming and tedious
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
