Painting KZ750 l3 engine
- kz750l3
- 1983 KZ750 L3 owner
21 Jun 2010 19:22
Hi Guys,
Do I need to strip off the factory paint to repaint my engine? How can I do the easiest clean up that will let the new paint stick? Thanks!
Re: Painting KZ750 l3 engine
21 Jun 2010 21:57 - 21 Jun 2010 22:06
Hello, Rod, and WELCOME to KZR!
We're glad you're here!
Could consider soda blasting, which should remove the loose paint.
There's a good article here in KZR forum on making an inexpensive quick and easy diy soda blaster. An air compressor is required.
Last edit: 21 Jun 2010 22:06 by Patton.
- kz750l3
22 Jun 2010 20:08
Thanks for the tip, I didn't look back far enough in the posts, DOH! I'm going to try to rig up the baking soda blaster, should hep to clean things up. thanks!
22 Jun 2010 20:17
Here's a link from the Tools category, all about the diy soda blaster.
Click > DIY Soda Blaster
