Engine cases powdercoat?
  • larrycavan
  • larrycavan's Avatar
Re: Engine cases powdercoat?
29 Apr 2010 19:26
#364327
Nice job on that bike :)
  • PLUMMEN
  • PLUMMEN's Avatar
29 Apr 2010 19:29
#364329
powder coating scares me on anything that cant be removed to have recoated easily B)
  • testarossa
  • testarossa's Avatar
29 Apr 2010 20:54
#364346
I thought that powder coating the head and cylinders of an aircooled bike was supposed to be a bad idea. From what I have heard, the powdercoating serves as an insulator, thus trapping heat in the motor. I have no experience with this, but I have heard that it will lead to a bike that runs hot. As for the cases, I don't think that it would do too much harm. However, I second the thought of not doing it on a 73 Z1. That stuff is a bitch to remove, and if I was shopping for the bike to do an original resto, then I would seriously devalue the bike because of this. OTOH, you have owned the bike for 37 years. Are you gonna sell it now? Do what you want, but I wouldn't powdercoat them myself.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • lewisj
  • lewisj's Avatar Topic Author
30 Apr 2010 07:22
#364401
No, I'm not selling it . It's still my baby, too many memories there.
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
  • kawsakiman
  • kawsakiman's Avatar
30 Apr 2010 11:16
#364449
sure you can!
here's mine after powdercoat.
  • KawiConvert
  • KawiConvert's Avatar
01 May 2010 23:21
#364894
For removing powder coating, buy a gallon of the dissolver/stripper. It will eat it off and leave bare metal. Otherwise it will take forever with a wire wheel. Even a poorly applied coating like my brake lever got took hours to clean off. I tried propane torch, a scraper, and finally a wire wheel. I didn't have the stripper so that was out of the question at the time.
Kawasaki Man, those cases look good.
As for trapping heat, highly unlikely as it is bonded to the surface and is not much of an insulator. However, you can check the constants of aluminum and PC to be sure on the heat transfer qualities.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
02 May 2010 06:38 - 02 May 2010 07:23
#364928
kawsakiman wrote:
sure you can!
Looking FINE! :cheer:
What about jugs and head? :unsure:
Good Fortune! :)
Last edit: 02 May 2010 07:23 by Patton.
02 May 2010 06:43
#364930
KawiConvert wrote:
For removing powder coating, buy a gallon of the dissolver/stripper. It will eat it off and leave bare metal....
Where is the dissolver/stripper available? :unsure:
Good Fortune! :)
  • testarossa
02 May 2010 07:06
#364933
A quick search on thermal conductivity yeilded this website: www.finishing.com/244/25.shtml
Looks like the powdercoat is substantially less conductive of heat than aluminium. Now this is just an internet find from some random person of unknown qualifications. We all know that what you find on the internet must be true. Now the amount of insulation it provides is minimal due to the thickness that the coating is applied, but for those who ride in the heat, it may be a consideration. As I said before, I have zero real world experince with this, and I don't plan on finding out. FWIW, I think that it looks killer on engine cases, but I live in Houston and I'm not taking chances on overheating.
2004 ZX-10R
Angola, IN
  • KawiConvert
02 May 2010 19:59
#365104
Good Fortune! :)
www.eastwood.com/ew-powdercoat-and-paint-dissolver-quart.html
I've never used it, but I've had good luck with what I have purchased from them in the past.
  • KawiConvert
02 May 2010 20:00
#365105
I'm in the desert where we don't have that nice humidity to help transfer heat to/from the engine depending on which is hotter. Which is one of the reason's I'm installing an oil cooler. Better safe than sorry.
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
03 May 2010 18:49 - 03 May 2010 18:52
#365318
Think we are splitting hairs here. If Kawasaki painted their engines cases on the z1r and MK II black and whatever the stuff they used is still adhering to those fins and cases thirty years later I would think that there is no real worries. My friends z1r engine has 86000 miles on it and it is still going strong. Of course if the coating is really thick I am sure it wouldn't be a great thing to do but my cases I can tell you for sure are coated properly and the coating is thin. But do what you like. I paid to have mine done right and it was expensive.
I personally think the engines look great all aluminum as long as they are spiffy clean but the coating of black is so much easier to clean and look nice but it kinda hides the engine for my tastes a bit. Keeping up with all the cleaning when bikes get riddin so much is quite a chore. Black has to be much easier to clean if you ask me.
79 LTD B3
Last edit: 03 May 2010 18:52 by saxjonz.
