Engine cases powdercoat?
- lewisj
28 Apr 2010 07:36
Can the engine cases of a 73 Z1 be powder coated or is therea heat issue? I know the powder coating process involves "baking" the paint on, but wasn't sure if there are problems associated with the engine heat. Thanks in advance for your help.
Jim
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- JakeB
Re: Engine cases powdercoat?
28 Apr 2010 08:14
All of the powder coating websites I have seen showed at least one picture of a cylinder block coated. If it can take the heat of an air cooled cylinder I imagine the cases shouldn't be a problem. I'm not sure if they use a special powder or what, but if you go to a reputable powder coater they should know what to do.
1978 Z1-R
- MDZ1rider
28 Apr 2010 09:34
My local Powder coating shop did not recommend it. This was a few years ago and powder technology may have improved since. They could not guarantee against wrapage. Cases are considerably thinner material than a cylinder. They are not designed to withstand anywhere near the temperatures that a cylinder block is normally subjected to.
I've been happy with the PJ1 FastBlack S (satin).
- lewisj
28 Apr 2010 10:23
Thanks MDZ! I have acan of Satin ready to go. Just thought I would see what the general consesus was. I will also check with the powder coater and get his opinion.
thanks Jim
thanks Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- MFolks
28 Apr 2010 11:14
I've found that if you can bake the painted part for 1 hour at 350 F, it will make for a more durable coating.
I use our electric oven with the parts hung on the wire racks using coat hanger wire.I suppose welding/brazing rod would work too.
Probably have to open windows to vent as the fumes may make the wife/girlfriend as why the house stinks.
- austin3119
28 Apr 2010 16:05 - 28 Apr 2010 16:08
This one is powdercoated (head,cylinders,case), gets ridden a lot and looks great. I say powdercoat away.
It's not mine.
It's not mine.
Last edit: 28 Apr 2010 16:08 by austin3119.
- jeffasaki
28 Apr 2010 16:21
DO NOT powdercoat a 73 Z1 pls.But I guess its your bike so do what you want.Just saying man bring it back to what it was
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- KawiConvert
28 Apr 2010 21:02
PC'ing engine parts is fine. Just don't get it in the engine. There is high temp stuff available, but still bake it at 400 F for 20 minutes. Not likely that you'll warp something that fast. I've done a head cover and clutch cover with no problems.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- lewisj
29 Apr 2010 07:56
jeffasaki,
I know what your saying, but I have owned this bike since new (37 years)and it wasn't stock when it left the showroom floor., headers pods, always adding something. Who would have known in 73 that they would bring this kind of money 30 yars later. She's always been a great bike, just needs some spit and polish and a 1075 upgrade , better suspension. paint and........ oh you know how it goes!!!
Thanks for caring! Ride on!
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- lewisj
29 Apr 2010 07:58
austin 3119,
That bike looks awesome. I will look into the powder coat!
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- saxjonz
- KawboyZ
29 Apr 2010 13:13
I got my cases powdercoated! It's not cheap but it looks great!
I will post up pics when my bike gets done but if any of you guys are interested in the progress I have posted pics up on facebook look for kawboyz chicago area kz riders.
79 LTD B3
- saxjonz
- KawboyZ
29 Apr 2010 13:18
austin3119 wrote:
Hey! How bout some more pics of this bike. I had an idea like that for my paint. Checkered flag and carbon fiber. This thing looks sweet
79 LTD B3
