any recomended step by step painting d.v.d's folks
- Old Man Rock
Re: any recomended step by step painting d.v.d's folks
31 Jan 2010 02:47
Well if you can find it.... What ever Kawi paint was on the ZX rims is amazing crap for this was a sonsabitch to get off....
Seriously, in using a Nylon wire brush wheel on a drill, took some time to get that down to bare metal on the rims for buffing....
This stuff was some truly tough ass paint...
Would be perfect for frame paint so if you happen to find out what it is please share...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- trianglelaguna
31 Jan 2010 04:44
sunday shopping list...
sand blaster -cheaper depot version
spray gun.....maybe a gravity feed kit with some goodies to boot....
jasco..aircraft..and some other strippers...
primers...sand bags...wire wheels,sand blocks ,s papers,naval jellies,wire brushes,gloves,tarp, and rustolleum metal and plastic primers and some dupli test colors....
also settled on this guys 2 hr dvd to watch one night for any little tips...really in depth no nonsense appraoch
he can be googled under " Len Stuart Spray Painting 101 DVD" seems like what i'm after...
so...OMR...what about the oven cleaner soak...brake fluid soak????any chems even able to move the surface coats...or was it very strong rim paint.....
i mental noted to
use a pan and rag and soak my side covers,tailpeices,and small bracketts in lotts of brake fluid over night
to use aircraft stripper and wrap the frame in plastic untill it has done it's best on a layer ...then pressure waswh and re-do......
gonna maybe see if i canb get set up to start stripping next sat.....
i mental noted to
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Kawickrice
31 Jan 2010 04:58
Aircraft stripper works real well just dont get any on you. If you sand down your side covers a little then sandblast it will leave a nice surface for the primer to grab. I also sandblasted my frame after hitting it with some sand paper. Sandblasting can be time consuming but in my opinion it works the best at getting rust out of those nooks and crannies that a frame has. You can use a chemical stripper then finish with sandblasting. It is amazing how much rust is under the paint that you can not see untill you start stripping it. I have a plastic spray bottle of rust converter that woks excellent on bare metal after stripping, Navel jelly is a joke in my opinion and takes forever to work.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- trianglelaguna
31 Jan 2010 05:51
good tip...i will copy this stuff to a list today...i only said naval jelly cause thats what i remember seeing when i was a kid...pretty pink.....tip taken.....tip toucher:laugh:
Kawickrice wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
