OK So Here's the evidence that PEANUT OIL works
  • Tommotbird
  • Tommotbird's Avatar Topic Author
11 Jan 2010 10:25
#342566
OK so here is the image of the airbox as it was posted on Ebay USA before it was sent to me here in th UK.
I will have to post the after picture separately as I don't know how to post multipics
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
  • Tommotbird
Re: OK So Here's the evidence that PEANUT OIL works
11 Jan 2010 10:31
#342569
Right here is the picture so far, it actually looks better in real life as there is some camera glare.
Another treatment or two and some hard rubbing (the airbox that is)and it will just get better.
No easy fix for these things but it is definitely working.
The area on the left below the holes for the rubbers was completely grey/ white and the area above is moving away nicely.
Try it for yourselves- definitely makes a big improvement. Ideal for the KZ's that don't have the chrome airbox covers either side.
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
11 Jan 2010 11:07
#342572
Good post.
To to photobucket.com and get a account to post multible photos. It's free. Roy
  • otakar
  • otakar's Avatar
11 Jan 2010 11:16
#342573
I use lemon oil on my tires. This is because it is a very fine and organic oil that will not brake down the rubber. The problem is that it dries in about 3 days. The question is, how long will this treatment last? and what makes it different than using any other oil to seal the plastic pores. I would think that any oil will shine up the plastic. That is the whole idea of ArmorAll. It uses Silicone to seal the plastic.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Tommotbird
11 Jan 2010 11:32
#342576
Hi Otakar
Please try it, the oil seems to get below the surface and remove any traces of white & grey. I have dried the airbox off so there is no sign of surplus oil, I obviously don't know yet how long it will last. My intention is to give it another couple of treatments with plenty of rubbing it in, I will then clean it off and autowax it.
I am usually very skeptical about these "remedies" and I am not into alternative medicines either, but I am delighted with the results so far.
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
  • Old Man Rock
  • Old Man Rock's Avatar
11 Jan 2010 11:38
#342578
Can you take another picture from approximately the same angle & zoom as in the first one for comparisons...?
Should also help on flash glare...
Thanks,
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Kawickrice
  • Kawickrice's Avatar
11 Jan 2010 11:56
#342579
Amazing stuff there, even diesel motors can run on peanut oil
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Tommotbird
11 Jan 2010 12:16
#342580
Hi OMR
Thanks for your interest in the thread.
What I will do is persevere for a couple of days more and then post the picture result.
Must admit that I am truly amazed but as Otakar said lets seehow long it lasts.
For me it has turned a very average airbox that I might have skipped into something that I will be proud to have on my bike!
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
  • otakar
  • otakar's Avatar
11 Jan 2010 15:25
#342601
What I would try is to wash it now with regular dish washing detergent and see if it is still shiny after that. Also if you are just not making it look so good with the good old "Elbow Grease" that you are applying in copious amounts. I do know one thing and that is, peanut oil like Castor oil turns into a varnish when it drys. This is why peanut oil is used on Iron skillets. You wipe it on and than bake it in. It is as good as Teflon.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
11 Jan 2010 15:28
#342602
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
12 Jan 2010 05:24 - 12 Jan 2010 05:24
#342652
I've done the same thing with my handlebar controls using just WD40...
Last edit: 12 Jan 2010 05:24 by 9am53.
  • Tommotbird
12 Jan 2010 11:30
#342678
Thanks for that link Otakar, That was the one that I originally read.
It definitely works!!!
Pointless exercise making arguments as to why it won't!
Easy solution is try it for yourselves then you have the proof.
I might even try the wintergreen & xylol on the airbox boots!
One thing is for sure is that the 303 SPF40 Aerospace Protectant doesn't make a jot of difference in softening the rubbers. Might be a good idea to spray new ones with it and it could prolong their lives.
Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
