18" front mag wheel for KZ650?
  • seanof30306
  • seanof30306's Avatar Topic Author
13 Dec 2009 21:46 - 13 Dec 2009 21:47
#338873
I've read that some Z1R and Police models had 18" front mags that are a direct fit on a KZ650. Is that orrect? if so what years/models?
Thanks
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
Last edit: 13 Dec 2009 21:47 by seanof30306.
  • otakar
  • otakar's Avatar
Re: 18" front mag wheel for KZ650?
14 Dec 2009 04:24
#338895
The ONLY direct replacement mag wheel in 18" would be the 1978 Z1R the rest are 19". The police wheel you require different discs for. The Z1R uses the standard four bolt disc hub. The police wheel already uses the more modern flat disc with the large hubless opening. If you are interested I do have a police wheel for $100. I never did get the chance to buy the discs though. I wanted to put it on my GPz1100 but decided to go with a different wheel instead. I paid $125 for it about six months ago and just want to get rid of it. I have already had the old dry rotted tire removed that was on it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • seanof30306
Re: 18
14 Dec 2009 04:52
#338897
Thanks for the information. At this point, I'm just gathering information, I'm not ready to buy yet. Honestly, I'd prefer to go with the direct replacement when I do buy, so i can reuse the new pads and resurfaced rotors I already have.
Thanks anyway, though.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • otakar
  • otakar's Avatar
Re: 18
14 Dec 2009 05:14 - 14 Dec 2009 05:14
#338899
Good luck on finding a 78 Z1R wheel. I've been looking for the last two years and when you do find them the're $350 or more. I have only found two in the last two years and at those high prices.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Dec 2009 05:14 by otakar.
  • otakar
  • otakar's Avatar
Re: 18
14 Dec 2009 05:35
#338906
By the way, the 81 KH110C2, 80 KZ250-G1, 79 250-A1, 80 250-A2, 81 250-A3, 81 250-J1, 85 KZ305-C2 79 400-G1, 80 400-G2, 81 400-G3, 80 440-C1, 81 440-C2, all also had disc brake seven spoke 18" mags that would fit your bike with the four bolt disc hub pattern.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
Re: 18
14 Dec 2009 05:38
#338908
By the way, what year and model KZ650 do you have??
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
14 Dec 2009 06:54 - 14 Dec 2009 07:19
#338919
I'll be swapping on a '78 Z1R front wheel this Winter, so I'll let you know how it goes.
Mark Wing has a Police wheel, 18", on his 650, but he has a completely different front end on.
USD forks from a ZX I believe.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
Last edit: 14 Dec 2009 07:19 by rstnick.
  • seanof30306
Re: 18
14 Dec 2009 12:33 - 14 Dec 2009 12:36
#338955
It's a '79 KZ650 B3, but it has dual front discs.
And all of those models have the same width front wheel as mine does?
Thanks
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
Last edit: 14 Dec 2009 12:36 by seanof30306.
  • otakar
  • otakar's Avatar
Re: 18
14 Dec 2009 12:53
#338958
The center hub is the same with.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • seanof30306
Re: 18
14 Dec 2009 13:04
#338959
What about the rim width? And will they work with dual discs?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • otakar
  • otakar's Avatar
Re: 18
14 Dec 2009 13:59 - 14 Dec 2009 14:01
#338962
There are two rim widths 2.15 and 1.85 They will take the same tires. I am not sure which are dual disc and which are single only. You would have to do some research. There are also two axle sizes that Kawasaki uses. You might have to change the bearings or get a different axle.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Dec 2009 14:01 by otakar.
  • otakar
  • otakar's Avatar
Re: 18
14 Dec 2009 14:11
#338964
What did you do for a rear drum mag wheel? did you convert to disc?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
