18" front mag wheel for KZ650?
  • seanof30306
  • seanof30306's Avatar Topic Author
Re: 18
14 Dec 2009 14:18
#338967
No, the bike came with mags, but it's 19" in the front, and I really like that "staggered" look like the Zephyr has, so swapping to the 18" rim to get that is worth it to me.
And I'm keeping the drum in the rear, as I use my bike as a daily commuter (or will once i get it to the point where it doesn't eat an electrical system or foul the plugs in under 400 miles). In wet weather, I feel the drum is safer, as it gives me much better control. My experience with discs on the rear in wet weather is they're much more like "on/off" switch, locking up easily.
I think I have the best of both worlds; the dual disc fronts stop on a dime in dry weather, and the drum rear lets me modulate the rear brake easily for maximum safety.
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • otakar
  • otakar's Avatar
Re: 18
14 Dec 2009 14:31
#338969
You said that it was a B-3, that came with spoke wheels, not mags. And if it is a 79 C-3 which came with mags, that had a disc in the back. The only 650s tat came with 18" drum rear mags were the F series 80-81.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • seanof30306
Re: 18
14 Dec 2009 14:55 - 14 Dec 2009 15:17
#338978
All I know is that my bike is a '79 KZ650 B3. It has mags, dual front discs and a drum rear. I assume some changes were made to the bike, as the carbs have accelerator pumps (which I know came on '79 models) and non-adjustable jet needles, which I understand, didn't show up till '81. I'm also pretty sure someone made the conversion to the dual front discs, as to the best of my knowledge, no bikes were made in '79 with dual front discs and drum rears, and it has the single disc front master cylinder.
Regardless, the the title lists it as a 1979 KZ650 B3, serial number: KZ650B532898.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
Last edit: 14 Dec 2009 15:17 by seanof30306.
  • RonKZ650
  • RonKZ650's Avatar
Re: 18
14 Dec 2009 15:48
#338984
otakar wrote:
By the way, the 81 KH110C2, 80 KZ250-G1, 79 250-A1, 80 250-A2, 81 250-A3, 81 250-J1, 85 KZ305-C2 79 400-G1, 80 400-G2, 81 400-G3, 80 440-C1, 81 440-C2, all also had disc brake seven spoke 18" mags that would fit your bike with the four bolt disc hub pattern.
This is interesting as none of these models are even recognized as being built according to my Kawasaki parts CD. Any of these wheels will be few and far between in the USA at least.
  • Kawickrice
  • Kawickrice's Avatar
Re: 18
14 Dec 2009 16:11
#338986
I have an 18" rear mag wheel that is a drum on my 900 I have no idea what it came on originally but it will not fit my 650 due to the differences in drum sizes between the 900 and the 650. I like the rear drum in the rain also. My GS1100 has a rear disk that is kinda touchy.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Arvex_Costello
  • Arvex_Costello's Avatar
Re: 18" front mag wheel for KZ650?
11 May 2017 16:15 - 11 May 2017 16:16
#761763
Hi there! Im also going crazy trying to turn my 1981 kz550 into front 18" mag (2 disk brake). Do you think that the z1r's will do? ($250 on eBay). How about the 1980 kz 1300's? Any help would be much appreciated.
Last edit: 11 May 2017 16:16 by Arvex_Costello.
  • mjg15
  • mjg15's Avatar
12 May 2017 00:47 - 12 May 2017 07:56
#761798
Not sure that it would be a bolt-on, but may be something that would work with some machining. It would probably be easier to adapt a 650 front end, along with the 18" Z1R wheel. It (the 18" Z1R wheel);should bolt up to the 650 (or 750E) front end
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Last edit: 12 May 2017 07:56 by mjg15.
12 May 2017 07:11
#761820
mjg15 wrote: Not sure that it would be a bolt-on, but may be something that would work with some machining. It would probably be easier to adapt a 650 front end, along with the wheel. It should bolt up to the 650 (or 750E) front end
That wouldn't accomplish the objective. KZ650 models all had 19" front wheels. I believe he is trying to mount an 18" front wheel on his bike. Ed
  • mjg15
  • mjg15's Avatar
12 May 2017 07:57
#761822
Fixed
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
