removing deep scratches from DOHC engine side cove
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
05 Dec 2009 20:25
I bought used 'DOHC' engine side pieces for my '78 kz1000 and I want to remove some deep scratches in the aluminum, about 1/32 deep in the worst scratched area near the bottom.
I don't know *exactly* what tool to use.
(I should be able to use myself as I AM a friggin tool sometimes.) :blink:
I'm thinking either my Dremel or my handheld drill.
But I have never removed deep scratches from the kz1000 (soft?) aluminum side case covers, actually have never removed deep scratches from ANYthing.
Anyone have a suggestion about what type of Dremel attachment to use or what type of buffing or grinding wheel to use on my hand drill?
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- ready2ryde1985
- got to love these kzs
Re: removing deep scratches from DOHC engine side cove
05 Dec 2009 20:33
I have the same problem and wet sandin just aint getin it !!!!!!!!!!
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- PLUMMEN
05 Dec 2009 20:59
block sanding is best way i know of fixing it,dremel will just leave waves in cover
- newOld_kz1000
05 Dec 2009 21:13
PLUMMEN wrote:
I was afraid of that, waves. Plummen, what grades of sandpaper work for this? Do you start with, say, 40 or 60 to remove enough material to go flat, then do a 100/200/400/600 series using a sanding block? And is wet sanding the way to go?
- PLUMMEN
05 Dec 2009 21:47
depends on how bad the scratches are,using much meaner than 80 to start will leave lots of new scratches to sand out.if theyre reall bad you can start with a file to save some work then go to block sanding.depending on finish you want you can wet sand when finished or use aluminum polish.
- kzr750r1
06 Dec 2009 06:20
I'd start with 100 grit... Not too much and work up from there... Take your time and only hit that specific area with the hard stuff. The finer you go youll cause less damage.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- Old Man Rock
06 Dec 2009 07:34
Follow the link named BUFFBOOK.pdf...
Provides everything you need regarding buffing....
kzrider.com/index.php?option=com_docman&...d&gid=427&Itemid=108
It's the basics of what I used and my cases even had holes in them....:blink:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
06 Dec 2009 07:38
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
06 Dec 2009 07:41
I had a very bad road rash one, that i bought on eBay. I first removed the damage on a belt sander and than started using finer and finer sand paper until it was gone and I could buff it out. It only took about 20 minutes to do and it is almost impossible to notice now, because everything is blended evenly.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kzr750r1
06 Dec 2009 12:04
The bitch is scrubbing a fresh powder coat cover then having to repair with out starting from scratch.
Lucky in my case the stator cover FU is on the bottom but still noticeable, to me. Not many lookup at a KZ. I'll be able to get away with a touch up with some gloss epoxy case paint and it will not be noticed.
Makes me think twice about powder in the future...
How is it respraying guncoat if a oops occurs?
Although I admire and appreciate a clean polished motor I know it's not for me.
- newOld_kz1000
06 Dec 2009 22:04 - 06 Dec 2009 22:06
otakar wrote:
Sounds efficient -- the less time it takes to work through menial stuff the less chance you'll put off doing it!
I VERY much appreciate the other advice here!
I took 80 grit with a sanding block as Plummen suggested and got the right side DOHC ready for finer grit and buff, thanks Plummen.
I'm checking out that link too Rock, thanks.
But the left side DOHC alternator cover is bad and I think I'll try the belt sander -- I own a belt sander -- and the scratches are deep -- Otakar, what grit did you start with on the belt sander? I reckon I'm at 1/32" at the deepest....
Last edit: 06 Dec 2009 22:06 by newOld_kz1000.
- Iron Duke
- what are you rebelling against?
07 Dec 2009 00:37
Random orbit sander, will not leave whirl marks, best damn sander I've ever used, and I use it in all applications,woodworking,auto body,just anything you sand this beats all other forms,belt, disc, block hands down. regards Duke
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
