media blasting my engine
  • thompsonmx100
  • thompsonmx100's Avatar Topic Author
13 Nov 2009 19:23
#333537
Hey all, I am going to bead blast my engine this weekend and wanted some advice. I have completely disassembled the engine down to bare cases. I want to know how to go about keeping media out of areas i don't wnat it in. I was thinking I would put the cases back together with the oil pan and then tape up the ignition, stator, clutch and jug holes. sound like a good plan? Let me know what you guys think I'm sure someone on here has done this.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
  • ndfez
  • ndfez's Avatar
Re: media blasting my engine
13 Nov 2009 19:53
#333541
Have u ever heard of soda blasting,alot easier to clean out the finished product only needs water to clean.I have a article about the soda blasting see if I can post it.
  • ndfez
  • ndfez's Avatar
13 Nov 2009 19:54
#333542
www.aircooledtech.com/tools-on-the-cheap/soda_blaster/
  • Headly
  • Headly's Avatar
13 Nov 2009 21:03
#333555
Just stripped my motor and had it soda blasted recently and it came up awsome,like you said washes out with water so no need to stress about leaving medium in your oil galleries.:)
73z1a fireblade front&rear,75z1b,74z1a,05 husky 510,xl567.
Ask the toe cutter,he knows who i am!
  • thompsonmx100
14 Nov 2009 10:30
#333620
Yeah i have a soda blaster but it doesn't work that well. takes forever to take paint off.
1985 gpz750
Kz 650
  • thompsonmx100
14 Nov 2009 12:06
#333639
noone has done this or has any tips? other than soda blasting.
1985 gpz750
Kz 650
  • Zacknhs
  • Zacknhs's Avatar
14 Nov 2009 20:11
#333733
I've never done it either but it's on my list for the winter my new place has a garage so I'll actually be able to work on my bike and car. I've lived on campus for 6 years and haven't had a garage or even a flat piece of pavement to work on in years. I have a 110lb media blaster from harbor freight. i was trying to decide if i was going to use glass beads or buy the retrofit kit from Eastwood to convert it to soda. It runs $120, but may be worth it since I'm planing on striping the whole bike.
Columbus, Ohio
Go Bucks
1978 Kz1000 <- first bike and i love it!!
  • flht1997
  • flht1997's Avatar
15 Nov 2009 06:10
#333809
Media blasting will be fine and give you a real good finish, everyone complains that you get residue in the oil if you dont clean it good enough. just clean it good then! We have a place in Milwaukee called U-Spray where you do your own blasting and pay by the minute. Glass bead gave me what i thought was the best finish the other media just did not look right. You may want to thread all the bolts you can into there holes. you will want to tap them out before reassembly anyways but if they are plugged with media and the thread have been rounded over from the blasting it can become tiresome.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
15 Nov 2009 07:56 - 15 Nov 2009 08:13
#333828
diy soda blasting tool
Click Here
Good Luck! :)
Last edit: 15 Nov 2009 08:13 by Patton.
  • thompsonmx100
15 Nov 2009 08:06
#333833
thanks for the help. I picked up the blast cabinet and the glass bead yesterday and started with my clutch cover it came out pretty good. I did find the cabinet that I bought is too small to fit my engine in assembled. I will have to have the top and bottom seperate. I plan on taping up the bearing surfaces and just being careful as to where I point the gun. Although the glass bead seems to be pretty gentle. I will post pics of the finished product in my build thread.
1985 gpz750
Kz 650
  • Kawickrice
  • Kawickrice's Avatar
15 Nov 2009 08:48
#333843
Polish the covers when you are done and they will shine like chrome. I have seen a big plastic tub rigged as a cabinet that would fit all your parts in. might be something to think about for the big stuff. Clean,clean,clean is the only way to get all the media out. I used to take my smallblock Chevy blocks to the carwash to clean them when I was done blasting.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • MFolks
  • MFolks's Avatar
15 Nov 2009 09:47
#333851
The company where I worked at some years ago rebuilt the refueling nozzles for Diesel Locomotives, The nozzles were disassembled,blasted with glass beads,washed in soap and water, and dried before re-assembling.
A surprising amount of glass bead grit was at the bottom of the washing tub when it was changed weekly.
