media blasting my engine
- Headly
Re: media blasting my engine
16 Nov 2009 00:25
Bead blasting gives a good finish for sure,just be wary if you want to polish the covers that it can pit the surface if the pressure is too high.I learnt this the hard way when i did my CB1100 Boldor cases and stuff,just created a lot more wet rubbing than i had to when it came to polish.(Shit load more blisters too, :laugh:).
73z1a fireblade front&rear,75z1b,74z1a,05 husky 510,xl567.
Ask the toe cutter,he knows who i am!
- thompsonmx100
Re: painting my engine
03 Dec 2009 19:37
Hey everyone i have finished bead blasting the lower engine cases. I have come to the conclusion that the soda would have been a better I dea. I taped up critical areas but still ended up with glass bead where I didn't want it. If it would have taken longer with the soda I would have saved time by not needing to clean the engine for three days straight. Anyhow I am now ready to paint my question is I currently have the engine apart I was thinking about assembling the engine then taping and painting, but have since thought that maybe i might be better off painting it disassembled. Anyone have any advice on this matter
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- Martynbiker
- 1993 KZ1000P
03 Dec 2009 23:34
thompsonmx100 wrote:
a soda blaster is not meant for paint, it is a gentle abrasive for delicate uses like carb bodies, cylinder fins etc....
Yeah i have a soda blaster but it doesn't work that well. takes forever to take paint off.
If you cant fix it with a Hammer....... it's gotta be an Electrical problem...
- Martynbiker
- 1993 KZ1000P
03 Dec 2009 23:35
paint it disassembled.
mask all holes with tape
take your time
let it harden a WEEK before reassembly and then be careful.
Enjoy!
martyn
take your time
Enjoy!
martyn
04 Dec 2009 06:27
What Martyn said.
- thompsonmx100
04 Dec 2009 14:23
Yeah thats what I was thinking. I will probably do that this weekend then i will have to wait a week for parts anyhow. I have used the soda blaster to remove paint before it just takes longer cause it is softer. But it will take off paint. I'm gonna do my head and cyliders with it once I'm to that point. Thanks all.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- Kawickrice
04 Dec 2009 14:52
Where is the best and cheapest place to get the soda media? I do not have a cabinet and lose it all when blasting. Where do you get the box of arm n hammer in that size?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- PLUMMEN
04 Dec 2009 15:35
if youre really worried about use some heavy duty paint stripper to remove the paint then soda blast everything to make look uniform.dishwashers are da bomb for fine cleaning,just use water no soap and dry parts really good when done.
- mark1122
- Keep twisting it
04 Dec 2009 15:35
if u are going to paint it, i would stick with the glass. even sand. u will get better adhesion for the paint. the rougher surface will actually help the engine run cooler . the surface will dissipate heat 15% better when blasted and painted with .003" black Guncoat paint. This is according to Pop Yoshamira, back in 1980.
Take your time and tape it well. put old bolts in every hole. It is a very tedious job.
degrease it first, so the media is less likely to stick. Blast away.
after u have completely cleaned the media out.
wash it with Acetone, or high quality thinner, Don’t use cheap thinner, it will leave a residue, and the paint wont stick.
Paint it as thin as possible, so it wont chip as easily.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
