No rattle can
- jimstan
No rattle can
29 Oct 2009 15:43
Just finished my first NON rattle can paint job.
I used A two part primer, House of Kolor base coat green Fine Platinum flake with three coats clear. The bike is my 1977 KZ650.
- Locozuna
Re: No rattle can
29 Oct 2009 16:55
Looks like British Green. Nice. Didn't you paint the tail?
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
Re: No rattle can
29 Oct 2009 20:16
jimstan wrote:
I have a question, from the context of a person (me) about to do a non-rattle-can paint job also.
That 'House of Kolor' paint is 'spensive so I've heard! How much did you use, and how much $$ did it cost?
- Did you use an acrylic or enamel primer?
- was the base coat an acrylic paint or enamel paint?
- this might be just the photo quality -- but why doesn't it look glossy? I thought clear-coating it would make it glossy?
And if I'm wrong about the clear coat adding a gloss -- how do professional (as in body shop) painters manage to get bike tanks to look so shiny?
I like the color and especially the metallic flake in it!
The machine's in excellent shape too.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- rstnick
Re: No rattle can
30 Oct 2009 06:39
Well done.
She looks great!
She looks great!
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- jimstan
Re: No rattle can
30 Oct 2009 19:39
Primer was a two part polyester.
For the base coat I used HOK Green # SG113 it is premixed ready to spray, I used two 4oz bottles only cost $13.00. Acrylic or enamel? as far as I can tell its both ,as you can use ether type of clear over it.
The lack of gloss is the lighting and my old camera.
I will be color sanding and buffing this weekend that will make it pop.
- otakar
Re: No rattle can
31 Oct 2009 06:15
How come the paint came out so dull? What kind of clear did you use. Mine always shine like they were wet. Here is a picture of mine, that I did.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Re: No rattle can
31 Oct 2009 06:16 - 31 Oct 2009 06:17
Here is one closeup. I have not yet put any kind of sealer on it plus it has not been washed in over a year.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 31 Oct 2009 06:17 by otakar.
- racer54
Re: No rattle can
31 Oct 2009 13:37
The wrong thinner/reducer grade can cause the paint to look less glossy. Which humidity determines which grade you should use. Might just be like he said about camera and such but if the paint was mixed with a thinner/reducer for normal conditions and paint is sprayed with higher humidity level, the moisture in the air can dull things down somewhat. Different thinners/reducers dry at different rates and if it dries too fast (slow rate of thinner/reducer) then the paint dries too fast and loses some of it's shine. Always best to use thinner/reducer rated a little slower then needed to give paint chance to flow but that does give paint more time to collect unwanted ingredients also so it's a trade-off.
- otakar
Re: No rattle can
31 Oct 2009 20:05 - 31 Oct 2009 20:07
I always mix my own reducer with Toluene, Xylene, and M.E.K. I haven't used an over the counter reducer for years. For the clear coat I use straight Toluene 5-10%. I also always allow my clear coat to pre-catalyze, and use it during it's final hour of pot-life. I put four coats of clear coat on fuel tanks and fairings with three coats on all other parts.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 31 Oct 2009 20:07 by otakar.
- racer54
Re: No rattle can
31 Oct 2009 20:08
What are those that you mentioned? They sound familiar though. I would really like to know what M.E.K. is and where you get it. Was told to use that to thin out sealers like Yamabond when coating cases and such.
- Kawickrice
Re: No rattle can
31 Oct 2009 20:17
racer54 wrote:
Methyl Ethel Keytone can be bought at any hardware/paint store
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- otakar
Re: No rattle can
31 Oct 2009 20:59
MEK Methyl Ethyl Ketone belongs to the Acetone family of solvents, with three major differences from Acetone. It is not hygroscopic like acetone, it drys slower and it is 100% compatible with all Urethanes and Enamels.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
