How to? strip paint from plastic
- GregZ
16 Oct 2009 19:21
Whats the best way to remove a few coats of paint from plastic side covers and the tail?? Is there a safe chemical stripper or bead blast, sandpaper??
thanks
gregz
thanks
gregz
Re: How to? strip paint from plastic
16 Oct 2009 20:22
Brake fluid reportedly does a pretty good job removing the paint without damaging the plastic body parts.
Have never tried this, so please await more confident advice.
Good Luck!
Good Luck!
- MFolks
16 Oct 2009 20:25
Two words: Brake Fluid! It will strip paint and not do any damge like regular paint stripper will.
Get a soft bristle brush for the stubborn areas, use some solvent resistant gloves and try to do it in a well ventilated area as the chemical action might smell.
A through scrub with some hot water and soap should remove any residue.
16 Oct 2009 20:28
MFolks wrote:
That's pretty confident. :lol:
Good Luck!
Two words: Brake Fluid! It will strip paint and not do any damge like regular paint stripper will....
Good Luck!
- GregZ
17 Oct 2009 01:24
Not only will I try it ,I will post before and after photos for future referance
Cheerz
gregz
Cheerz
gregz
- Gman
17 Oct 2009 06:54
I wish I had asked before I ruined a Z1 tail piece with aircraft paint stripper last summer. Applied the stripper and then hit it with the pressure washer. Totally ruined, I felt pretty stupid and mad at the same time. Curious to see the results from the brake fluid method.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
2002 Gold Wing
1974 Z1 900 project
- MentalMike
- God Bless America!
17 Oct 2009 07:06
GregZ wrote:
Please do gregz, I've got all the plastic body parts from my project bike to strip and I had the same question you did.
Love to see your results.
Good luck.
Cheerz
gregz
Good luck.
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
1976 Kawasaki KZ900
- KawiConvert
17 Oct 2009 07:36
with a light sandblaster it is possible to strip paint from plastic as well. However an industrial gun will do some damage.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- 78z1Joe
- My man cave is my garage....
17 Oct 2009 17:47
One of the warnings on a side of can of brake fluid is to avoid spilling it on any painted surface. If it does, rinse it at once with plenty of cold water as it will remove the paint. I have very successfully used brake fluid to remove paint from plastic model trains. Rarely have I heard of any damage to the plastic. As previously stated, use a soft brush and planty of cold water and soap to clean off the old paint and brake fluid residue. The original plastic mold color could be black, white or gray, and I have never had the plastic damaged. I would think that the motorcycle manufacturers would use better quality plastic on their bikes than a model boxcar manufacturer whose products are made is some plant in China.
However, if I had a spare side cover, that would be the place to start. good luck.
1978 KZ 1000
1982 GS 300 training bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
69 3 1/2 HP mini bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
17 Oct 2009 23:34
I've used brake fluid before to strip side covers. Worked great. I made a form-fitting "bowl" with alum foil to minimize the amount of fluid needed to maintain full coverage. I can't remember exactly how long I let it soak, but it seems like I left it overnight. There was no damage to the plastic. "Most" of the paint just slid right off. There were still a few stubborn spots, however, which I ended up just sanding off.
However, cleanup afterwards is very important. The fluid can hide out in microscopic pores in the plastic, and will emerge after you repaint to cause lifting of the new paint.
I cleaned the parts with soap & water as thoroughly as possible. Then I ran them through a dishwasher cycle just to be sure. Didn't have any problems after repaint.
West Linn, OR
- Jeff.Saunders
18 Oct 2009 04:44
PPG (and others) make a paint remover specifically for plastic parts. Any auto parts store should have or can get this for you.
- GregZ
18 Oct 2009 18:22
Jeff.Saunders wrote:
Thanks Jeff and once again thanks for the great service at Z1 enterprise. top notch!!
gregz
gregz
