How to? strip paint from plastic
  • Kawickrice
  • Kawickrice's Avatar
Re: How to? strip paint from plastic
19 Oct 2009 08:44
#328394
I used brake fluid then finished off with sand blasting. The sandblasting will remove anything left on there and rough up the plastic for excellent adhesion of the primer.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • chance
  • chance's Avatar
  • Life long biker/
19 Oct 2009 16:04
#328452
I would use this and sand plastic with 400 grit clean with soap and water dry, apply plastic parts adhesion promoter comes in a spray can. Then Apply plastic parts flexable primer also comes in a spray can sand and paint.
  • 550A2
  • 550A2's Avatar
  • keep the shiny side up
19 Oct 2009 16:46
#328458
I sanded some side covers i had with like 180 grit, then hit it with brake cleaner and a parts washing brush with plastic brissels. Then wet sandid it again with a red scoch bright pad then 400 grit.
It worked! But the paint on it was an old spray paint job.
it didnt damage the plastic either.
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
  • YUKABODOS
  • YUKABODOS's Avatar
20 Oct 2009 14:33
#328616
320,400,600 wet dry sand paper + 2 buddies + case of beer + 2 packs of smokes + radio = properly cleaned side covers.
:blink:
  • chance
  • chance's Avatar
  • Life long biker/
21 Oct 2009 03:02
#328697
Jeff.Saunders wrote:
PPG (and others) make a paint remover specifically for plastic parts. Any auto parts store should have or can get this for you.
  • avidflyguy
  • avidflyguy's Avatar
22 Oct 2009 19:19
#329041
who makes this plastic adhesion promoter and primer? what about removal of bondo on plastic? does brake fluid remove that?
  • HerrDeacon
  • HerrDeacon's Avatar
23 Oct 2009 02:50 - 23 Oct 2009 02:51
#329095
I'm currently trying the brake fluid method and its not working for me very well. Its hardly doing anything to the paint. Its DOT 3 fluid and the paint is just Dupli-color lacquer, hardly doing anything to it. Just left it overnight and barely any change at all.
Last edit: 23 Oct 2009 02:51 by HerrDeacon.
  • arai59
  • arai59's Avatar
23 Oct 2009 06:39
#329112
I've said it before and I'll say it again.......don't use anything to remove paint from plastic parts other than elbow grease and various grit papers. Strippers especially PPG were not designed to remove layers of Krylon. That is the unfortunate result of DIY rattle can jobs. No bueno. Remember too....sand plastic parts easy and evenly. If you cut into the plastic primers and paints will swell or attack the plastic. And if you have any residue of stripper,brake fluid etc. left it will ruin your new finish. You can also have parts media or soda blasted. Although..... find a company who has done it before. If you need an adhesion promoter, there is a product named Bulldog. Works quite well.
  • racer54
  • racer54's Avatar
23 Oct 2009 12:53
#329157
I've never used the brake fluid idea...for some reason, it just doesn't seem like a good idea to me. Used to paint quite a bit years ago and that stuff, like oil, grease, etc. can mess up a good paint job real easy. Yea...a good cleaning should do but it only takes once and some of that hidden some where to come out at the last minute to mess up a lot of work. I have had sidecovers turn to jelly from stripping using chemicals (what a mess) and have always used a very gentle blasting media at times but mostly elbow grease and lots of sanding. I agree...if that plastic absorbs any of that liquid media and it isn't dry and you paint...you will get to do it all over again. Been there, done that also.
  • txturbo
  • txturbo's Avatar
  • Ex-Kawasaki Mechanic 1981-1985
25 Oct 2009 15:37 - 11 Nov 2009 18:39
#329574
I've heard that bologna strips paint.I've never tried it and don't know how long it takes. I always use Capt'n Lees paint stripper.No smell, safe for some plastics and fiberglass and it completely nuetralizes with water.
1984 ZX750 E1 GPz Turbo
1984 ZX1100 A2 GPz
1984 ZX900
1996 KZ1000P Police bike
1970 Honda CT 70H 4sp manual
1965 Honda Dream 305
2003 Honda Shadow 1100
1971 Suzuki MT50 Trailhopper
1969 Camaro SS
1966 Impala
1966 Impala SS 427/4spd
Last edit: 11 Nov 2009 18:39 by txturbo.
