Bigger Gas Tank
  • picinisco
  • picinisco's Avatar Topic Author
Bigger Gas Tank
14 Mar 2006 21:05
#31225
The tank on my KZ1000 police bike only holds about 3.5 gals seriously limiting distance between fill-ups. Does anyone know of a larger tank that can directly swap with this tank or one with a minimum of conversion.
Post edited by: picinisco, at: 2006/03/15 00:06
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: Bigger Gas Tank
15 Mar 2006 04:11
#31285
Find a KZ 1300 tank and check it out.Roy
  • picinisco
Re: Bigger Gas Tank
15 Mar 2006 06:17
#31297
Does this tank fit? Is there much modification necessary?
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Bigger Gas Tank
15 Mar 2006 06:24
#31299
picnisco:
I don't how deep your pockets are but you may want to consider an oversize Z1R tank. To the best of my knowledge, they weren't available in North America but were available in Europe as an option, so you'd have to watch the European eBay sites. The trouble you might run into with any oversize tank is that your stock seat may no longer fit.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • elr658
  • elr658's Avatar
Re: Bigger Gas Tank
15 Mar 2006 07:06
#31311
Z1R tank aint gonna work. The KZ1000P which you have is based on the KZ1000J. Frames are different. Try one for a 1981-82 KZ1100B.(if you can lay your hand on somebody's spare to try.)
  • KevZ
  • KevZ's Avatar
Re: Bigger Gas Tank
15 Mar 2006 09:51
#31342
Picinisco, where are you located? I have an 1100 with the tank off for a few weeks. If you are nearby, you are welcome to swing by and try it on for size.
  • picinisco
Re: Bigger Gas Tank
15 Mar 2006 09:57
#31343
Sunny Arizona I'm afraid. Need the bigger tank to travel to Minnesota.
John
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Bigger Gas Tank
15 Mar 2006 11:44
#31376
John:
Interesting, my uncle died in Show Low...really!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • picinisco
Re: Bigger Gas Tank
15 Mar 2006 11:51
#31377
Hopefully not at the hands of a policeman on a motorcycle!:ohmy:
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Bigger Gas Tank
15 Mar 2006 12:35
#31379
Naw...60 years of cigarettes...BTW, I have a KZ1100B2 tank (currently off my bike) and if you give me guidance on which measurements you need...I will supply those from my tank.:)
Post edited by: Mcdroid, at: 2006/03/15 15:37
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • elr658
  • elr658's Avatar
Re: Bigger Gas Tank
16 Mar 2006 06:17
#31610
Just compare how the rear of the tank mounts. As a GPz1100 tank mounts on a my R (therefore a J) with no issues. If it's got the tongue that plugs into the rubber grommet at the seat area you should be cool. I double checked the mounting system with my 81 GPz1100 which is right next to me. Also, seat nose and fuel gauge sender issues may surface, just swap senders. (round and oval)
  • picinisco
Re: Bigger Gas Tank
16 Mar 2006 07:21
#31620
The existing tank has a tab at the back as shown in the pic. Underneath at the front there are 2 "C" shaped pieces that mount on the rubber pieces on the frame. The dimensions that I would need would be the didtance between the 2 "C" shaped pieces and the distance from the "C" shaped pieces to the tab. Ideally from the center of the "C"
John
Post edited by: picinisco, at: 2006/03/16 10:24
