Best Way To Clean Aluminum?
- dearthchris
17 Jun 2009 04:28
Hey Guys,
So I want to clean up my 80 KZ250 LTD (starter bike). Paint looks great but the aluminum has the typical wear, grime, and fade going on. What is the best way to clean and polish up this aluminum. I plan on selling the bike after I get myself comfortable with riding and upgrade bikes.
What is the best products and the steps to do it right?
Thanks
Thanks
Re: Best Way To Clean Aluminum?
17 Jun 2009 05:04
If you have the time and patience, S100 Total Cycle Finish Restorer or X-treem polish both work very well on aluminum.
S100
X-treem
S100
X-treem
17 Jun 2009 05:08 - 17 Jun 2009 07:37
Double post.
Last edit: 17 Jun 2009 07:37 by 650ed.
17 Jun 2009 05:09
- larrycavan
- Visitor
17 Jun 2009 05:29
Am I reading you correctly? Did you use the S100 product on the cast aluminun to get it that brilliant?
- Jack
17 Jun 2009 06:09
Patience and elbow grease, along with liberal doses of Mother's Aluminum polish. If the S100 product got your 650 motor that clean without a fair bit of rubbing/wiping effort I'm getting a case...
[IMG][IMG]http://i251.photobucket.com/albums/gg309/JackMark2/DSCF9486.jpg[/img]
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- AtLarge
17 Jun 2009 08:04
If it's just grease, oil and road grime wiping it down with WD40 does wonders and looks decent when your done. Just don't let it puddle up in the motor crevices.
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
1994 BMW K1100RS
- Koda1
17 Jun 2009 10:36 - 23 Aug 2009 17:53
'78 CB750K
'82 650 Nighthawk
'82 KZ750
"The problem with socialism is that you eventially run out of other peoples money"
M. Thatcher
'82 650 Nighthawk
'82 KZ750
M. Thatcher
Last edit: 23 Aug 2009 17:53 by Koda1.
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
17 Jun 2009 13:09
I found that Meguires' Cleaner Wax works very well. I used it to take that sticky chain lube off. Brake cleaner can't do the things this cleaner wax does and it won't itch your plastic or mess up your paint.It's my secret weapon.
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
- KZ250LTD
17 Jun 2009 13:34 - 17 Jun 2009 13:36
79 KZ1000ST
Past:
Many.
Past:
Many.
Last edit: 17 Jun 2009 13:36 by KZ250LTD.
- KZ250LTD
- jimstan
17 Jun 2009 16:25
Wet sand with 320 grit then 800 then 1200 and buff to a shine
with a fine paste, the whole thing goes quick. Short cut are
more work in the long run .
JIM
JIM
