Frame Paint ???
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Frame Paint ???
08 May 2009 05:20
#289001
dupont imron is bulletproof, great paint...
I've heard this as well but had a hell of a time finding a distributor for it...
For next project.....ssssssssshhhhhhhhh... don't tell wifey! :laugh: Anyone have some links where to obtain?
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • otakar
  • otakar's Avatar
Re: Frame Paint ???
08 May 2009 06:05 - 08 May 2009 06:06
#289004
I used to use Imron. before I switched to PPG. First of all it is what is known as a "Modified IsoCyanide" and should only be sprayed with a fresh air respirator or an airtank respirator. It took me almost three years for the Cyanide to dissipate from my blood. I had to go once a month to have blood work done to monitor it. In comparison to the other paints mentioned it costs a small fortune. I have used POR-15 on frames a decade ago and it is still not showing any evidence of rust, besides that. it is not anywhere as toxic as Imron.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 08 May 2009 06:06 by otakar.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Frame Paint ???
08 May 2009 07:38
#289027
OMR
let me know when youre ready B)
  • DoubleDub
  • DoubleDub's Avatar
Re: Frame Paint ???
08 May 2009 09:21
#289043
Hmmm...nobody has tried the implement paint, eh?
I found some guys on the greatlakes4x4 site stating that they used it with the hardener on their Jeeps and other and it worked pretty well. I'm sure those things take a beating like a frame would.
I'll report back if it works out or not.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Frame Paint ???
08 May 2009 10:36
#289052
ive never had any luck finding hardener with the tractor supply paint around here,i know it doesnt hold up well on trailers without hardener anyway B)
  • DoubleDub
Re: Frame Paint ???
30 May 2009 14:30
#295088
Well, I'm done spraying/curing. So far I've nicked it a couple of times as I reassemble pieces, but I'm not sure what that means for durability. It seems harder than spray can paint, but I'm betting it will get dinged up pretty good after I ride this season. Oh, well - I'll take it to a pro this next winter and get it painted.
