Frame Paint ???
- ProStreet
Frame Paint ???
04 May 2009 17:42
I am restoring a 77 kz1000 ltd, don't have the $$$ for Powder Coating, anybody recamend a good,tough, chip resistant paint,for the frame, thats still stock looking ?
Thanks
Tom
Thanks
Tom
- otakar
Re: Frame Paint ???
04 May 2009 18:06 - 04 May 2009 18:08
There are three you can use which are absolutely fantastic. The best way to do it out of the three is Sherwin Williams "Polane". This is a two part poly urethane and is Impervious to all solvents. Polane will cost you about $125. It is a paint that is designed to go on bare metal. The next two are virtually identical and much cheaper. POR-15 & KBS The difference between the two is the price KBS is cheaper. Here is the link to KBS.
www.kbs-coatings.com/index.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 04 May 2009 18:08 by otakar.
- PLUMMEN
Re: Frame Paint ???
04 May 2009 20:22
dupont imron is bulletproof
- donthekawguy
Re: Frame Paint ???
04 May 2009 23:10
otakar wrote:
Powdercoating won't cost you that much.
There are three you can use which are absolutely fantastic. The best way to do it out of the three is Sherwin Williams "Polane". This is a two part poly urethane and is Impervious to all solvents. Polane will cost you about $125. It is a paint that is designed to go on bare metal. The next two are virtually identical and much cheaper. POR-15 & KBS The difference between the two is the price KBS is cheaper. Here is the link to KBS. www.kbs-coatings.com/index.html
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- jordan
Re: Frame Paint ???
05 May 2009 00:20
got my frame and rims powdercoated for $180. Just make sure the frame is exactly how you want it before powdercoating, as it is not as easy to go back and fix things later.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- otakar
Re: Frame Paint ???
05 May 2009 05:01
For the KBS Motorcycle frame kit you will pay $25 with postage and do all of the work your self. If it only costs $180 to powder coat a frame I would not bother with the DIY. UNLESS, you don't want to bother removing everything from the frame. That now is a different story.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- JMKZHI
Re: Frame Paint ???
05 May 2009 05:53
PJ1 Fast Black High-Gloss Epoxy frame paint
I don't know if it matches the stock color, but a number of folks have reported that it's a very good product. Here's one quote - not sure by whom:
I just recently went through this same dilemma and ended up with PJ1 Fast Black High-Gloss Epoxy frame paint. Had to order it from my local motorcycle PJ1 distributor, shits hard to find on the shelves.
On a piece of test metal, I originally tried engine paint enamels of various manufacturers but found they chipped rather easily by dropping bolts/sharp objects on the metal.
In the PJ1 testing in the same manner, it didn't chip at all. With a little harder force applied it did make a dimple/imperfection in the paint which would be expected even in powder coating but still no chipping! With this in mind, I painted my frame, so far so good.
- ProStreet
Re: Frame Paint ???
06 May 2009 19:20
Thanks guys
I am going to try Rustoleum, Applience Epoxy resin, a bike builder, friend of mine said he has used it many times, high gloss and hard as nails and witin my budget not working right now.
Thanks Again
Ride Safe
Tom
Thanks Again
Ride Safe
Tom
- riverroad
- 1980 1000LTD B4
Re: Frame Paint ???
07 May 2009 09:49 - 07 May 2009 09:58
Another option which is pretty cheap (don't laugh now) is John Deere tractor paint. You can get a hardener to go with it. Lot's of folks around here paint their boat trailers and of course their farm implements with it. I think it's an enamel.
Also comes in a spray can, but then you can't mix the hardener in. But it's still pretty tough without it.
Here's some on ebay: cgi.ebay.com/John-Deere-Hitachi-Black-Hi...yZ1267QQcmdZViewItem
But be careful, there appears to be other companies calling their paints 'John Deere' just because of the color.
Please use the black though. I saw a guy with a John Deere green bike one time with JD yellow wheels. :blink:
Last edit: 07 May 2009 09:58 by riverroad.
- Old Man Rock
Re: Frame Paint ???
07 May 2009 22:58 - 07 May 2009 23:01
The PJ1 test failed miserably... I also consider the possibility of improper prep, unknown for sure... But for $7 a can no thanks, too many chips for me, no happy with the results.
I tried many and ended up with Dupli Color Wheel coating. Designed for NON CHIP! After cure time, impact with flat blade screw driver....
Did it dimple, yes, did it chip NOPE!
Downfall, not a lot of colors but I wanted black as it was so good to go... Glad I chose paint over powder coat due to Uh-Oh, forgot about that... Sand down, weld & then repaint...
No one knows the difference....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 07 May 2009 23:01 by Old Man Rock.
- DoubleDub
Re: Frame Paint ???
07 May 2009 23:49
Anyone tried the Valspar Tractor & Implement Enamels with the add-in hardener? They carry it at the local Farm & Fleet around me and I picked up a quart of gloss black and the hardener to try out. Not sure exactly when I'll be able to spray it, but hopefully since it's a two part it will be tougher than a rattle can. If not, sand again and use something else, I guess....
It was the "non-toxic to livestock" that sold me....don't want to be poisoning my Kaw after all...
www.valsparglobal.com/val/resident/valspar_imp.jsp
- Russ Jackson
Re: Frame Paint ???
08 May 2009 04:59
PLUMMEN wrote:
great paint...Russ
great paint...Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
