Gas tank key lost
  • KZman66
  • KZman66's Avatar Topic Author
Gas tank key lost
27 Feb 2006 18:10
#26895
Anybody know how to get the gas cap off without the key? I lost the key to a nice replacement tank that I picked up and now I can't swap it with my old one. I don't want to mess up the new one trying something that won't work. :sick: :sick:
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: Gas tank key lost
27 Feb 2006 18:13
#26897
Which year KZ is it?
If it has the older style key, you should be able to open it with just about any other two-sided key.
Kawi didn't think to much about security where the fuel cap lock is concerned back in the 70's. :whistle:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • RonKZ650
  • RonKZ650's Avatar
27 Feb 2006 18:14
#26898
As far as I know all KZ caps are not keyed. In other words any key or a flat screwdriver that will fit will open it right up.
  • KZman66
27 Feb 2006 18:34
#26905
Its an 82. I tried the key for the old tank but no go:(
27 Feb 2006 18:54
#26916
That sounds about right.
I believe Kawi started using "real" keys for their fuel cap locks right about '80/'81.
A good locksmith should be able to pick that lock and make a new key for it for about $30-$45.
I was quoted $30 at a locksmith near me for the tank cap lock on my '84 ZN. Turns out it wasn't locked afterall, just "glued" stuck because the PO left fuel in it that had now turned to varnish. :angry: :ohmy:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
27 Feb 2006 19:03
#26921
My 1981 wasnt keyed, I open it with a Yamaha Key.
NO TUMBLERS or sliders.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
27 Feb 2006 19:13
#26925
There were no tumblers in the older ones, but there are two parts to the cylinder. So even if you get the top portion to turn with a screw driver it may not open. You need to get to the lower portion, about a 1/2 inch into the keyhole and turn there. Again almost any key that fits in will open it if it reaches in far enough to turn the lower part of the cylinder. The top is free spinning.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
27 Feb 2006 19:14
#26926
I'm willing to bet you probably could have even used a twig or anything narrow and strong enough to turn it.
That wouldn't be a lock then, silly.
It would be a simple latch actuated by turning it inside the fuel cap. :P
Heh :laugh:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
  • wireman
  • wireman's Avatar
27 Feb 2006 20:12
#26943
my kzs are all keyed alike on ignition,seat,gas cap:whistle:
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
28 Feb 2006 06:32
#27039
No tumblers until 1983. I have two 1982's and the same style key will open either tank. If it is an 1982 and doesn't open, then either the latch mechanism is problematic (= rusty, etc.) or you are using a different style key. But damn near anything, including a screwdriver, ought to work.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • wiredgeorge
  • wiredgeorge's Avatar
28 Feb 2006 06:35
#27040
The latch mechanism needs to be lubricated occassionally or can get where it turns REAL HARD.
  • hwms
  • hwms's Avatar
28 Feb 2006 12:07
#27113
You may get results if you push down on the cap while turning key.
