Gas tank key lost
  • wireman
  • wireman's Avatar
Re: Gas tank key lost
28 Feb 2006 12:44
#27134
that helps sometimes too!;)
  • KZman66
  • KZman66's Avatar Topic Author
28 Feb 2006 14:37
#27152
Thanks to all that offered their help. It's open thanks to all the good info. I was afraid to put too much force on the key and end up breaking it off(my luck runs that way). So some graphite lock lub and a little more torque did the trick. Thanks again.:woohoo: :woohoo:
  • Blackbmwdriver
  • Blackbmwdriver's Avatar
13 Sep 2017 14:00
#770845
Hello, I do not know how old this post is. And I am new to this site. But if you're wanting to remove the gas cap without a key , there is a roll pin in the hinge section of the gas cap. A 1/8 long punch will remove it. Then just lift it up. I hope this information helps someone
  • Nessism
  • Nessism's Avatar
13 Sep 2017 14:41
#770849
I recently misplaced the gas cap key for my '81 750 and even though the lock is rudimentary I couldn't find a screwdriver or similar key that could open it. Fortunately I eventually found the key, but I'd sure like to find a spare now...
  • martin_csr
  • martin_csr's Avatar
14 Sep 2017 06:24 - 14 Sep 2017 06:32
#770879
I'm using an Ilco KA/14 X/103 key on my 81 650-CSR. It's almost identical to the stock key in pic. There are probably other Ilco keys that could be used. see Ilco catalog.
Last edit: 14 Sep 2017 06:32 by martin_csr.
  • Nessism
  • Nessism's Avatar
14 Sep 2017 07:24
#770885
martin_csr wrote: I'm using an Ilco KA/14 X/103 key on my 81 650-CSR. It's almost identical to the stock key in pic. There are probably other Ilco keys that could be used. see Ilco catalog.
I've got a couple of those Ilco keys for my bike but the gas cap key is different - shorter length and fatter.
